- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
XUPV5 SFP module interfacin g and driver
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
07-15-2012 02:18 PM
I am trying to build a network bridge [1 Gbps - SGMII design] using XUPV5 board with 2 ports, one Ethernet Phy RJ45 connector and the other one using SFP module. Am using EDK design flow with microblaze soft processor. Am able to interface the ethernet PHY port and using lwIP TCP/IP stack to do networking.
I am stuck with interfacing the SFP module. Am using Finisar's FCMJ-8521-3 1000BASE-T Copper SFP transceiver for taking input to the XUPV5 board. But am not able to interface the SFP module.
1) Could somebody shed light on how to interface the same.
2) Are there any available reference designs/drivers which does the SFP interfacing.
3) Also, can I use xps_ethernetlite IP core to interface the SFP at 10/100Mbps, which is working fine with Ethernet Phy.
4) Or does SFP work only with xps_ll_emac IP core [soft_emac_wrapper 2.03] with SGMII/1000Base-X option?
Kindly help in proceeding with the design.
Thanks in advance.
