- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Need your comment on a portable D display connection design.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-15-2012 12:29 PM
I need to design a TX/RX pair which functions like a HDMI 1.4 3D, for a proprietary HUD. The source signals are 2 distinct TFT output in RGB, and the sinks are also two separate TFTs, and a stereo audio also need to be transferred in the same cable, but is on a lower priority.
The purpose is to reduce pin count of the cable connector.
LVDS signals on Xilinx spartan 6 could be transferred in meaning as GTP(PCIe) or SelectIO(TM) through IOB. The bandwidth estimation is about 600Mb/s in XVGA(single line).
Should i build a SerDes to bundle DVI(HDMI)signal in PCIe, or build something from scratch.
Thanks for your reading and your comment is valuable.
Re: Need your comment on a portable D display connection design.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-15-2012 12:45 PM
It would be good if you could focus your interests a bit more. Your initial post spans so many technologies and buzzwords, your "problem description" seems vague and 'random', and it is unclear what you are trying to accomplish.
-- Bob Elkind
Summary:
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-15-2012 12:54 PM
It's not clear to me how you want to use this link. Are you saying that you'll
have a Spartan 6 at each end of the link? How far does it need to run?
Someting like a headset cable (maybe 60cm?)
I would not suggest using PCIe, just because of the protocol overhead. Something
like Fiber Channel or serial FPDP would be simpler if you decide to use a GTP.
On the other hand, if each TFT only needs about 600 Mbps, then a couple pairs of
LVDS would be enough. 300 MHz DDR should be easy enough to accomplish
with general purpose LVDS I/O. One pair would transfer up to 600 Mbps using
whatever protocol you add to it. The tough part with general purpose LVDS is
clock recovery. You could use another LVDS pair to send a clock ala Channel-Link
(very common usage for industrial video - look up Camera Link). That clock could
also serve as the word frame if the cable skew is low enough. That's really the
tough part about Camera Link cabling and the reason it needs to be so thick.
Another odea may be to use one of the newer industrial video standards like
CoaxPress.
-- Gabor
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-15-2012 01:06 PM
i'm building a embedded device running linux by a ARM SOC chip, nothing fancy, except the display is not a conventional TFT LCD which drived by pixcel, line, and frame sync clock and 3*8bit RGB color signal, but TWO, to implement stereo display (actually two small OLED fitting in a gaugle).
The idea is to drive this Head-Up Display over a cable, of course 3D HDMI is an option, but implement it is such a huge task and i don't know something handy, so i need to do it somehow quirky, to reduce the wire required for the hud.
my idea is roughly to put two fpgas on each side of the cable, and convert raw LCD drive signal into DVI or something like to reduce wire count.
thank you for your advice of posting.
[ Edited ]- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-15-2012 01:28 PM - edited 05-15-2012 01:33 PM
Some thoughts to consider:
- LCDs are rarely 8-bit (per R|G|B) devices. Almost always they are 6-bit, using temporal dithering to approximate finer tonal gradations.
- Ignore the LCD frame rate. What frame rate is needed for your image content? For example, cinema is almost always captured at ~24FPS, but displayed at higher frame rates. Do you have motion content which demands a higher frame rate than 24FPS?
- Consider other data compression techniques, such as temporal data compression, transmitting frame-to-frame differences.
- DVI/HDMI/VGA signal formats all transmit H and V blanking intervals. Audio is embedded in the blanking intervals, but doesn't come close to filling up the data space. You can reduce bit rate considerably by not bothering to send H,V blanking interval data.
- DVI/HDMI is both a signal format and an electrical interface specification. You should distinguish these aspects when you reference DVI/HDMI. For example, both HDMI and DVI-D use TMDS-33 signal levels for video -- plus I2C in the out-of-band channel for EDID.
-- Bob Elkind
Summary:
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-16-2012 11:49 AM
If I heard you right you may want to reduce the wire counts.... referenced to the already exist 3D -HDMI ?
What is the number of wires you think may reduce to ?
Sound like you gonna invent something better than 3D -HDMI ?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-22-2012 11:56 AM
My data sheet has specified RGB 4:4:4 is a 8*3 input.
Thanks for your advice. After searching for solutions I found a micro-USB port physical compatible interface named MHL, it's a DVI aggregation ideal for my application.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-22-2012 11:58 AM
