Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
Regular Visitor
polyee13
0
Accepted Solution
Pin Placement of I2C / System Management Bus Clocks and Data lines
Do I2C/ SMBUS clock signals have to be routed to a GCLK pin of a Spartan-6 device? I'm running into some layout issues and a suggestion was made to move these clock and data signals from their current bank to another bank, which doesn't have any global clock pins.
Expert Contributor
rcingham
0
Re: Pin Placement of I2C / System Management Bus Clocks and Data lines
If the I2C/SMbus slave block you are using treats the SCK pin as a clock (rather than oversampling it for rising and falling edges), then it is doing things the hard way!
Regular Visitor
polyee13
0
Not sure if I understand your reply. Let's assume that it treats the clock lines as a clock.
Expert Contributor
bassman59
0
You missed his point. You should use your FPGA's high-speed global clock to oversample the I2C signals and look for levels. Remember that I2C isn't edge sensitive.
Yes, I do this for a living.
Expert Contributor
rcingham
0
[ Edited ]
"Not sure if I understand your reply. Let's assume that it treats the clock lines as a clock."
Don't assume. Find out.
If you looked at the HDL for the I2C block, would you understand it?
Regular Visitor
polyee13
0
So with that said, it really shouldn't matter if the I2C clock lines are allocated to a Global clock pin. It's not like the I2C clock is a clock that will be distributed through the FPGA for the logic other than the I2C core.
Expert Contributor
gszakacs
0
Correct.
To add to that, you should know that unless you have an FPGA or CPLD with hysteresis on the
inputs (Schmitt triggers) you should not even consider using the SCL line as a clock.  Its rise
time is much too slow.
-- Gabor
-- Gabor
Expert Contributor
bassman59
0
The I2C clock isn't used as a clock, full stop. It's a flag that, when high, indicates that the state of SDA is a valid logic level. When SCK is low, SDA can change, but SDA must be stable some setup time before the rise of SCK and cannot change until after SCK falls. So what is usually done is for the FPGA to oversample SCK, note when its rising edge occurs, and then wait a few (fast system) clock ticks before actually reading the value on SDA. You want to wait because, as noted, the rise time on SCK and SDA are not all that fast due to resistive pull-ups.
