- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
RAM access
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
04-11-2012 01:47 AM
HI
i would like to ask if its possible to access 2 adresses of the same ram at the same time, i mean does this make a problem in the synthesis of the ram or its better to make it in 2 different steps ?
process(clk)
begin
if rising_edge(clk) then
ram(addr)<=din;
end if;
end process;
dout1<=ram(3);
dout2<=ram(5);
Re: RAM access
[ Edited ]- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
04-11-2012 02:08 AM - edited 04-11-2012 02:14 AM
Your example requires three (not two) concurrent RAM accesses: a write access and two read accesses, with independent addresses for each..
From the ISE Language Templates>VHDL>Synthesis Constructs>Coding Examples>RAM>BlockRAM>Dual Port:
-- Ensure that the <ram_name> is correctly defined. Please refer to the RAM Type
-- Declaration template for more info.
-- The following code must appear before the "begin" keyword in the architecture
-- body.
constant ADDR_WIDTH : integer := <num_addr_bits>;
constant DATA_WIDTH : integer := <data_width>;
type <ram_type> is array (2**ADDR_WIDTH-1 downto 0) of std_logic_vector (DATA_WIDTH-1 downto 0);
signal <ram_name>: <ram_type>;
-- If using Dual Port, 2 Clocks, 2 Read/Write Ports use the following definition for <ram_name>
shared variable <ram_name>: <ram_type>;
process (<clock>)
begin
if (<clock>'event and <clock> = '1') then
if (<enableA> = '1') then
if (<write_enableA> = '1') then
<ram_name>(conv_integer(<addressA>)) <= <input_dataA>;
end if;
<ram_outputA> <= <ram_name>(conv_integer(<addressA>));
<ram_outputB> <= <ram_name>(conv_integer(<addressB>));
end if;
end if;
end process;
Or you can simply use the CoreGen Block RAM wizard.
-- Bob Elkind
Summary:
Re: RAM access
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
04-11-2012 02:49 AM
Dear sir,
in the case that i am using a FSM that takes the output of the memory at certian states whould this be ok
when s1=>
dout1<=ram(3);
dout2<=ram(5);
nxt_state<=s0;
and does the outputs from the ram should not exceed 2 at the same time ?
Re: RAM access
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
04-11-2012 03:41 AM
If you instantiate (or let the tools infer) a Dual Port RAM, as Bob helpfully explicitly stated, you can read from two addresses at the same time.
If you do not instantiate (or let the tools infer) a Dual Port RAM, you will not be able to do this.
If you need to access different parts of the same data array that is not a DP RAM at the same time, you could consider leaving it as a set of registers and not use a RAM at all.
Using an FSM should make no difference to this at all.
Howard
"That which we must learn to do, we learn by doing." - Aristotle
