Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
Regular Visitor
danbo.liang
0
Why this naming rule will report error?
Hi All,
in my design, there are 2 similar signals, one is ssn[2] and another is ssn_2, the port define is below:
input [2:0] ssn;
output       ssn_2;
when synthesize, ISE will report error "the net ssn_2 is not found", why?
Expert Contributor
drjohnsmith
0
Re: Why this naming rule will report error?
1001 resons,
    the most likely I gues is that  the signal is not used in th edesign,
               and is optimised away, a fairly common mistake.
It does raise the question of the naming convention yoru using,
     try changing ssn_2 to ssn_b
if ssn_b is reported as missing, its benn optimised away,
    if it reports ssn_2, oops....
Regular Visitor
danbo.liang
0
Actually, the signal is used.
After change ssn_2 to ssn_b, it is OK.
So I doubt that ssn_2 and ssn[2] are treated as same in ISE naming convention.
Expert Contributor
drjohnsmith
0
an interesting quirk
but at least you have a work around.
