Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
Super Contributor
maheshhegde
0
Re: signal is connected to multiple drivers
[ Edited ]
      The DATA_SIG is declared in command_signals.vhd.This file is the top file.That is going to ds1wm.vhd.from there this signal is routed to one_wire_io.vhd.I added that code also here.
Thanks You in Advance,
Mahesh Hegde.
Expert Contributor
joelby
In one_wire_io.vhd, you are assigning a value to DATA (which is eventually connected to DATA_SIG):
    DATA <= DOUT when DDIR='1' else "ZZZZZZZZ";
This is the cause of your problem. You've declared DATA as an inout in every module, and are driving it in two places.
The logic in one_wire_io.vhd looks like you're trying to infer a tristate IO buffer. Normally you would connect this to a top level pin - you wouldn't try to use tristate logic internally.
Super Contributor
maheshhegde
0
Hi joelby,
                  Yes you are right.Well catch.Thanks.Problem solved.
Mahesh Hegde.
javo0112
0
i have a machine state that drives the datta buffer but i was putting a "z" state when there was no data to transmit to the module DS1WM.  so that its wrong , isnt it?
Thank you
Javier Balam
maheshhegde1988
0
Hello Javo,
Intially I tried with DS1WM code to read and write of 1-Wire(Transducer).
After that i am not able to communicate with this chip using DS1WM.
So i left that path.(Communicating 1 Wire using DS1WM).
I wrote my own code to communicate with 1-Wire.
So i don't have much knowledge on DS1WM.
Thanking You,
Mahesh Hegde
javo0112
0
well i think i will try split that bus in two separate bus: one for input and the other for output.
if that doesnt work, i will have to make my own interface too .
thanks for taking the time to answer me
