- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
How to set the "Pack I/O Registers/ Latches into IOBs" property from command line
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-28-2012 10:08 AM
I have created a command line batch file to setup my ISE project and I would like to set this property to "For Outputs Only". What is the correct way to do this? Right now I have added the
project set "Pack I/O Registers/Latches into IOBs" "For Outputs Only" -process "Map"
entry to my .tcl file that I then call with the xtclsh command. However when I then open the ISE project that is created the option is always set to its default value ("Off"). Do I do sth wrong?
Thanx a lot!
Re: How to set the "Pack I/O Registers/ Latches into IOBs" property from command line
[ Edited ]
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-29-2012 02:22 AM - edited 05-29-2012 02:24 AM
What version of ISE tools?
"If it don't work in simulation, it won't work on the board."
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-29-2012 06:29 AM
I use
Release Version: 13.4 (nt64)
Application Version: O.87xd
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-07-2012 12:31 AM
The syntax appears correct, I performed a quick check of this in 14.1 and it appears this property is not being set when I rebuild the project aswell.
My tcl file uses:
I did try some other properties to see if they were updated, e.g.
project set "Starting Placer Cost Table (1-100)" "2" -process "Map"
This was applied correctly. There appears to be a problem with the "Pack I/O Registers/Latches into IOBs" property getting applied to the project correctly via the Tcl.
I cannot find any existing CR/bugs on this in our database and will file one. To workaround this you will need to manually set this I'm afraid.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
02-12-2013 05:17 AM
Can anyone answer this same question for Vivado? I don't see any way to set this option in Vivado.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
02-12-2013 10:12 AM
ISE supports two mechanisms for packing registers into IOBs. There is IOB=TRUE|FALSE|FORCE and also the map command switch -pr i|o|b which enables input|output|both packs for eligible registers, it is off by default. The -pr switch has no effect on registers that have IOB properties since the constraint takes precedence over the command line switch.
Vivado supports the IOB property but only TRUE|FALSE. The TRUE behavior is equivalent to the ISE's FORCE behavior in that the tool errors out if the IOB pack is not possible. Vivado has no feature equivalent to ISEs -pr option. If a register is eligible for both input and output packs, the behavior can be controlled with other constraints such as LOC constraints to the ILOGIC/OLOGIC site involved.
