Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
Regular Visitor
rohini.patil
0
ISE 12.1 fails with map error
Hello All,
In mapping I am getting error as
ERROR:Pack:2604 - The register
   Inst_system/SDR_SDRAM_CUSTOM/SDR_SDRAM_CUSTOM/mpmc_core_0/gen_sdram_phy.mpmc_
   phy_if_0/u_phy_ctl_io/gen_addr[9].u_ff_addr has the property IOB=FORCE, but
   was not packed into the output side of an I/O component. The output register
   symbol
   "Inst_system/SDR_SDRAM_CUSTOM/SDR_SDRAM_CUSTOM/mpmc_core_0/gen_sdram_phy.mpmc_phy_if_0/u_phy_ctl_io/gen_addr[9].u_ff_addr" has loads outside the I/O
   component.
   The output register symbol
   component.
   phy_if_0/u_phy_ctl_io/gen_ba[0].u_ff_ba has the property IOB=FORCE, but was
   symbol
   "Inst_system/SDR_SDRAM_CUSTOM/SDR_SDRAM_CUSTOM/mpmc_core_0/gen_sdram_phy.mpmc_phy_if_0/u_phy_ctl_io/gen_ba[0].u_ff_ba" has loads outside the I/O
   component.
   component.
   phy_if_0/u_phy_ctl_io/gen_ba[1].u_ff_ba has the property IOB=FORCE, but was
   symbol
   "Inst_system/SDR_SDRAM_CUSTOM/SDR_SDRAM_CUSTOM/mpmc_core_0/gen_sdram_phy.mpmc_phy_if_0/u_phy_ctl_io/gen_ba[1].u_ff_ba" has loads outside the I/O
   component.
   component.
   phy_if_0/u_phy_ctl_io/gen_cs_n[0].u_ff_cs_n has the property IOB=FORCE, but
   symbol
   "Inst_system/SDR_SDRAM_CUSTOM/SDR_SDRAM_CUSTOM/mpmc_core_0/gen_sdram_phy.mpmc_phy_if_0/u_phy_ctl_io/gen_cs_n[0].u_ff_cs_n" has loads outside the I/O
   component.
   component.
   phy_if_0/u_phy_ctl_io/u_ff_we_n has the property IOB=FORCE, but was not
   packed into the output side of an I/O component. The output register symbol
   "Inst_system/SDR_SDRAM_CUSTOM/SDR_SDRAM_CUSTOM/mpmc_core_0/gen_sdram_phy.mpmc_phy_if_0/u_phy_ctl_io/u_ff_we_n" has loads outside the I/O component.
and some more similar to this.
Can anyone help me?
Is there any constraint that needed to be given in the UCF?
bwade
0
Re: ISE 12.1 fails with map error
You need to either remove the IOB=FORCE constraints from the FFs or remove the internal fanout which makes them ineligible for an IOB pack.
Expert Contributor
gszakacs
0
It looks like you wrote some code of your own to do an SDR SDRAM interface?
Some tips:
If you code with VHDL and you need feedback from a register that goes to a pin,
DON'T make it an INOUT or BUFFER port.  Make it an output and use an internal
register signal for the feedback.  This will allow the tools to replicate the register
(one for the feedback, one for the IOB) rather than forcing feedback from the pin
or use of a single register driving both OBUF and internal loads.  Make sure
you enable register duplication to allow the register to be packed into the IOB.
Same goes for Verilog, use an output port, not an inout.  You don't need to define
an internal variable in Verilog for feedback, however.
If you think there should not be this problem (don't see where the internal loads are),
you can change the "FORCE" to "TRUE" to demote these errors to warnings.  Then
you can look at the technology schematic or open the design in FPGA editor to
see where these signals go.
HTH,
Gabor
-- Gabor
Regular Visitor
rohini.patil
0
Giving the constraint IBO = TRUE fro all these nets solved my problem
Expert Contributor
gszakacs
0
rohini.patil wrote:
Did it?  Are your flip-flops now pushed into the IOB's?  Or did it just remove the
errors, but you still have to deal with sub-optimal timing in the results?
-- Gabor
ginagrec
0
I too am seeing the same error. Where do we give the IOB = TRUE constraint? In the ucf?
Thx,
Gaurang
ambrosef
0
Xilinx constraints guide should show you how to apply this.
Here's the link to 13.4 version of this doc:
http://www.xilinx.com/support/documentation/sw_manuals/xilinx13_4/cgd.pdf
