Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
justin.delva
0
ISE 13.x & Synplify Pro BRAM utilization report mismatch
[ Edited ]
PART: xc6vsx475tff1759-1
Tools: Synplify Pro E-2010.09-SP2
            ISE 13.3
There's a BRAM utilization mismatch in my design. I use Synplify Pro to generate the netlist. The BRAM utilization shown by Synplify Pro is 78%. When I run that netlist through ISE, I get a BRAM over-mapped error (128%). What could  be the cause of this mismatch?
Here's Synplify's resource usage report (.srr file):
Resource Usage Report for ws6vpxcpe
Mapping to part: xc6vsx475tff1759-1
Cell usage:
BUF             3 uses
BUFIO           32 uses
DSP48E1         337 uses
FD              55673 uses
FDC             12259 uses
FDCE            12847 uses
FDC_1           20 uses
FDE             113031 uses
FDP             653 uses
FDPE            889 uses
FDP_1           18 uses
FDR             19891 uses
FDRE            44693 uses
FDS             842 uses
FDSE            753 uses
GND             5894 uses
IBUFDS_GTXE1    8 uses
IDELAY          4 uses
IDELAYCTRL      1 use
IODELAY         72 uses
IODELAYE1       262 uses
LD              4 uses
MMCM_BASE       4 uses
MULT_AND        1 use
MUXCY           516 uses
MUXCY_L         2649 uses
MUXF7           4667 uses
MUXF8           1918 uses
RAM128X1D       48 uses
RAM64M          7710 uses
RAM64X1D        330 uses
RAMB16          1304 uses
RAMB18E1        223 uses
RAMB36E1        69 uses
ROC             1 use
VCC             5894 uses
XORCY           2842 uses
LUT1            3271 uses
LUT2            37788 uses
LUT3            32096 uses
LUT4            10830 uses
LUT5            13317 uses
LUT6            21678 uses
LUT6_2            52 uses
I/O ports: 987
I/O primitives: 1357
IBUF           18 uses
IBUFDS         80 uses
IBUFG          2 uses
IBUFGDS        2 uses
IDDR           10 uses
IOBUF          201 uses
IOBUFDS        24 uses
ISERDESE1      200 uses
OBUF           162 uses
OBUFDS         80 uses
OBUFT          232 uses
ODDR           20 uses
OSERDES        326 uses
BUFG           12 uses
BUFGCE         3 uses
SRL primitives:
SRLC32E        1 use
SRL16E         2102 uses
I/O Register bits:                  0
Register bits not including I/Os:   152827 (25%)
Latch bits not including I/Os:      4 (0%)
RAM/ROM usage summary
Dual Port Rams (RAM16X1D): 4824
Dual Port Rams (RAM64X1D): 330
Simple Dual Port Rams (RAM64M): 7710
Dual Port Rams (RAM128X1D): 48
Block Rams : 833 of 1064 (78%)
DSP48s: 337 of 2016 (16%)
Global Clock Buffers: 15 of 32 (46%)
Mapping Summary:
Total  LUTs: 141718 (46%)
 Number of unique control sets:              272
Mapper successful!
Here's usage report from ISE (.mrp file):
Design Information
Command Line   : map -ol high -t 4 -mt 2 -w -xe n -o ws6vpxcpe.ncd -pr b
-detail -power off -register_duplication off ws6vpxcpe.ngd
Target Device  : xc6vsx475t
Target Package : ff1759
Target Speed   : -1
Mapper Version : virtex6 -- $Revision: 1.55 $
Mapped Date    : Tue Nov 22 06:37:46 2011
Interim Summary
Slice Logic Utilization:
  Number of Slice Registers:               256,918 out of 595,200   43%
    Number used as Flip Flops:             256,914
    Number used as Latches:                      4
    Number used as Latch-thrus:                  0
    Number used as AND/OR logics:                0
  Number of Slice LUTs:                    116,504 out of 297,600   39%
    Number used as logic:                   76,438 out of 297,600   25%
      Number using O6 output only:          37,253
      Number using O5 output only:           1,728
      Number using O5 and O6:               37,457
      Number used as ROM:                        0
    Number used as Memory:                  39,843 out of 122,240   32%
      Number used as Dual Port RAM:         38,028
        Number using O6 output only:        36,572
        Number using O5 output only:           432
        Number using O5 and O6:              1,024
      Number used as Single Port RAM:            0
      Number used as Shift Register:         1,815
        Number using O6 output only:         1,623
        Number using O5 output only:             0
        Number using O5 and O6:                192
    Number used exclusively as route-thrus:    223
      Number with same-slice register load:      0
      Number with same-slice carry load:       223
      Number with other load:                    0
Slice Logic Distribution:
  Number of LUT Flip Flop pairs used:      271,978
    Number with an unused Flip Flop:        40,952 out of 271,978   15%
    Number with an unused LUT:             155,474 out of 271,978   57%
    Number of fully used LUT-FF pairs:      75,552 out of 271,978   27%
    Number of unique control sets:           6,630
    Number of slice register sites lost
      to control set restrictions:          25,471 out of 595,200    4%
  A LUT Flip Flop pair for this architecture represents one LUT paired with
  one Flip Flop within a slice.  A control set is a unique combination of
  clock, reset, set, and enable signals for a registered element.
  The Slice Logic Distribution report is not meaningful if the design is
  over-mapped for a non-slice resource or if Placement fails.
  OVERMAPPING of BRAM resources should be ignored if the design is
  over-mapped for a non-BRAM resource or if placement fails.
IO Utilization:
  Number of bonded IOBs:                       579 out of     840   68%
    Number of LOCed IOBs:                      473 out of     579   81%
    IOB Flip Flops:                             30
    IOB Master Pads:                           104
    IOB Slave Pads:                            104
    Number of bonded IPADs:                      2
Specific Feature Utilization:
  Number of RAMB36E1/FIFO36E1s:              1,365 out of   1,064  128% (OVERMAPPED)
    Number using RAMB36E1 only:              1,365
    Number using FIFO36E1 only:                  0
  Number of RAMB18E1/FIFO18E1s:                231 out of   2,128   10%
    Number using RAMB18E1 only:                231
    Number using FIFO18E1 only:                  0
  Number of BUFG/BUFGCTRLs:                     15 out of      32   46%
    Number used as BUFGs:                       12
    Number used as BUFGCTRLs:                    3
  Number of ILOGICE1/ISERDESE1s:               202 out of   1,080   18%
    Number used as ILOGICE1s:                   10
    Number used as ISERDESE1s:                 192
  Number of OLOGICE1/OSERDESE1s:               361 out of   1,080   33%
    Number used as OLOGICE1s:                   11
    Number used as OSERDESE1s:                 350
  Number of BSCANs:                              0 out of       4    0%
  Number of BUFHCEs:                             0 out of     216    0%
  Number of BUFIODQSs:                          24 out of     108   22%
  Number of BUFRs:                               0 out of      54    0%
  Number of CAPTUREs:                            0 out of       1    0%
  Number of DSP48E1s:                          175 out of   2,016    8%
  Number of EFUSE_USRs:                          0 out of       1    0%
  Number of FRAME_ECCs:                          0 out of       1    0%
  Number of GTXE1s:                              0 out of      36    0%
  Number of IBUFDS_GTXE1s:                       1 out of      18    5%
    Number of LOCed IBUFDS_GTXE1s:               1 out of       1  100%
  Number of ICAPs:                               0 out of       2    0%
  Number of IDELAYCTRLs:                        27 out of      27  100%
  Number of IODELAYE1s:                        322 out of   1,080   29%
    Number of LOCed IODELAYE1s:                 48 out of     322   14%
  Number of MMCM_ADVs:                           4 out of      18   22%
    Number of LOCed MMCM_ADVs:                   3 out of       4   75%
  Number of PCIE_2_0s:                           0 out of       2    0%
  Number of STARTUPs:                            1 out of       1  100%
  Number of SYSMONs:                             0 out of       1    0%
  Number of TEMAC_SINGLEs:                       0 out of       4    0%
Mapping completed.
See MAP report file "design.mrp" for details.
Problem encountered during the packing phase.
Design Summary
Number of errors   :   3
Number of warnings : 418
Expert Contributor
rcingham
0
Re: ISE 13.x & Synplify Pro BRAM utilization report mismatch
Are there any IP cores used that Synplify would have treated as "black boxes"? If so, do any contain BRAM?
As an additional comparison, you could do a synthesis run using XST.
justin.delva
0
[ Edited ]
There are no black boxes in the synplify implementation. All the resources used are listed by synplify. If there was a black box, it would have been listed.
ywu
0
Can you double check the .mrp file to see if there are other errors reported? If map errored out before starting packing BRAMs, the BRAM utilization is not accurate and should be ignored until the other errors are corrected.
Cheers,
Jim
justin.delva
0
Hi Jim,
There are no errors in the .mrp file.
Since I am using such a large part (V6 SX475T) with 1064 36kBRAMS, could there be an issue with ISE in instantiating a certain large number of these BRAMs?
viviany
0
justin.delva wrote:
Hi Jim,
The report you posted shows you have 3 errors in MAP. Are the 3 errors all about the BRAM overmapped?
I would suggest to open the synthesized netlist in PlanAhead and find how many RAMB18s and RAMB36s are used in the design.
Vivian
