Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
rediboy
0
Routing Failure (GTXs Clock)
[ Edited ]
I'm facing a failure when the compiler trying to route "gtxs_module_0_Q4_CLK1_MGTREFCLK_PAD_N_IN_pin_IBUF".(Passing Synthesize, Translate and Map, but failing PAR without error message and with warning message fail to route "gtxs_module_0_Q4_CLK1_MGTREFCLK_PAD_N_IN_pin_IBUF".)
In my work, Virtex 6 (FF1156) is being used where 4 GTXs (in QUAD115) are configured as transmitter and REFCLK1 Q4 is selected for all the GTXs.
The GTXs are initiated in use_logic.vhd file and its input clock (REFCLK1 Q4 ) is routed in from system_top as external signals.
And Pin assignment is as follows (in ucf file)
May I know What I should do to resolve this problem?
  ################################## Clock Constraints ##########################
NET "q4_clk1_refclk_i" TNM_NET = "q4_clk1_refclk_i";
TIMESPEC "TS_q4_clk1_refclk_i" = PERIOD "q4_clk1_refclk_i" 6.4;
# User Clock Constraints
NET "gtx0_txusrclk_i" TNM_NET = "gtx0_txusrclk_i";
TIMESPEC "TS_gtx0_txusrclk_i" = PERIOD "gtx0_txusrclk_i" 7.407;
NET "gtx0_txusrclk2_i" TNM_NET = "gtx0_txusrclk2_i";
TIMESPEC "TS_gtx0_txusrclk2_i" = PERIOD "gtx0_txusrclk2_i" 3.704;
#################### locs for top level ports (ML623 Board) ###################
####################### GTX reference clock constraints #######################
NET gtxs_module_0_Q4_CLK1_MGTREFCLK_PAD_N_IN_pin  LOC=F5;
NET gtxs_module_0_Q4_CLK1_MGTREFCLK_PAD_P_IN_pin  LOC=F6;
################################# mgt wrapper constraints #####################
##---------- Set placement for gtx0_gtx_wrapper_i/GTX_DUAL ------
INST "gtxs_module_0/gtxs_module_0/USER_LOGIC_I/GTX_i/gtx0_GTX_i/gtxe1_i" LOC=GTXE1_X0Y12;
##---------- Set placement for gtx1_gtx_wrapper_i/GTX_DUAL ------
INST "gtxs_module_0/gtxs_module_0/USER_LOGIC_I/GTX_i/gtx1_GTX_i/gtxe1_i" LOC=GTXE1_X0Y13;
##---------- Set placement for gtx2_gtx_wrapper_i/GTX_DUAL ------
INST "gtxs_module_0/gtxs_module_0/USER_LOGIC_I/GTX_i/gtx2_GTX_i/gtxe1_i" LOC=GTXE1_X0Y14;
##---------- Set placement for gtx3_gtx_wrapper_i/GTX_DUAL ------
INST "gtxs_module_0/gtxs_module_0/USER_LOGIC_I/GTX_i/gtx3_GTX_i/gtxe1_i" LOC=GTXE1_X0Y15
mcgett
0
Re: Routing Failure (GTXs Clock)
It appears that something went wrong in synthesis and an IBUF was added before the IBUFDS_GTXE1 that should be used for the MGT (GTX) REFCLK.
Note: In the future please include the exact ERROR message that is report from tools along with the ISE version.
Have you tried typing your question into Google? If not you should before posting.
