Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
Regular Visitor
anding
0
Timing score problem in SmartXplorer
Hello I am using SmartXplorer in increment cost table mode (ISE 13.2).  SmartXplorer is listing a timing score of zero for all CT values, but when I click through "Done" to see the actual results under each strategy I see the actual timing score is often not zero at all (e.g. 6555 or something).  I can confirm that the non-zero value is the correct one by using "copy results" and then re-running PAR before seeing the results again.
Any ideas on how to resolve this?
Many thanks,
Anding
bwade
0
Re: Timing score problem in SmartXplorer
SmartXplorer initially uses the PAR timing score, but then switches to the TRCE timing score for the summary. It's possible that you are using non-default TRCE options that cause this discrepencey. If you are using default TRCE options, then the discrepency is a bug and should be reported via a webcase.
