Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
applefat
0
Re: map fails to integrate hard macro
I created another circuit, even more basic. It's just a single LUT with an input and an output. When I try to instantiate this, I get the following:
ERROR:Place:835 - Given the original pre-placement, no legal placements can be
   found for 1 group(s). The following is the description of these group(s). The
   relative offsets of the components are shown in brackets next to the
   component names.
        LUT puf3/Q_OBUF (0, 0)
        FF puf3/Q_OBUF (0, 0)
My code for the entire macro is below:
entity top is
    port(
        x: in std_logic;
        q: out std_logic
end top;
architecture Behavioral of top is
    signal t: std_logic;
    attribute lock_pins: string;
    attribute lock_pins of tri2 : label is "all";
begin
tri2 : LUT5
generic map (
INIT => X"55555555") -- Specify LUT Contents
port map (
O => t, -- LUT general output
I0 => x, -- LUT input
I1 => '0', -- LUT input
I2 => '0', -- LUT input
I3 => '0', -- LUT input
I4 => '0' -- LUT input
q<=t;
end Behavioral;
bwade
0
Are you setting the slice as the reference comp? Can you attach the macro along with your other source in a zip file?
applefat
0
I did set that.
Attached is a project for my target device. It is the simplest test I can think of, but it also did not synthesize.
Three important files:
top.vhd--file that instanciates the macro
puftest.vhd--file from which the macro was created
puftest.nmc--the macro file I created
Thanks bwade for taking a look.
bwade
I used your existing NGC and NMC files and I was able to get this to work by adding a UCF LOC constraint:
INST i0 LOC =SLICE_X0Y2;
I was also able to place the macro manually in FPGA Editor. The bug is just that auto-placement can't handle the macro. I see that you never defined a reference comp for the macro. That doesn't seem to matter for this single component case. For a larger macro you'll probably need to do that to LOC it successfully
applefat
0
Ah yeah, it works now, it was just the missing LOC. In retrospect, it's clear why that should be necessary, especially for very large macros. If it's essential though, in the future maybe a note should be added to the Xilinx reference page, for others....
One last question. I did set the reference comp in fpga_editor. Is there a code constraint you were looking for?
Thanks a lot for your help!
bwade
0
You define the reference comp in the editor. A circle will then appear in that comp. Maybe you just didn't save that version. There's no reason the placer can't handle the macro. I've filed a CR for the placer bug.
