Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
songxin
0
"WARNING:ConstraintSystem:203"
Hi, everyone
I'm using ML605 Evaluation Board to do my project and now I encountered a problem, call for help!!
When the project goes to translate process, it pops out these warnings
such as
"WARNING:ConstraintSystem:203 - A target design object for the Locate constraint
   '<INST: UniqueName:
   /EncoderTop/EXPANDED/EncoderTop/soft_enc_i\/embd_stub\/embd_system/DDR3_SDRAM
   /DDR3_SDRAM\/mpmc_core_0\/gen_v6_ddr3_phy.mpmc_phy_if_0\/u_phy_read\/u_phy_rd
   clk_gen\/gen_loop_col0.u_...>' could not be found and so the Locate
   constraint will be removed.
   '<INST: UniqueName:
   clk_gen\/gen_loop_col1.u_...>' could not be found and so the Locate
" and etc
It seems that those locate constraint didn't work.
Here is my Project Hierarchy
EncoderTop/soft_enc_i/embd_stub/embd_system/....
Hopefully Somebody could help me?
songxin
And my EncoderTop.ucf is like this
//          UCF FILE
# Encoder Top
NET  sys_clk_in_p            LOC = J9  | IOSTANDARD = LVDS_25 | DIFF_TERM = TRUE;
NET  sys_clk_in_n            LOC = H9  | IOSTANDARD = LVDS_25 | DIFF_TERM = TRUE;
Net sys_rst_pin PULLUP;
Net sys_rst_pin LOC= H10 | IOSTANDARD=SSTL15;
## System level constraints
Net sys_rst_pin TIG;
Net sys_clk_in_p TNM_NET = dcm_clk_s;
TIMESPEC TS_dcm_clk_s = PERIOD dcm_clk_s 5000 ps;
## adding by rong
NET "sys_rst_pin" CLOCK_DEDICATED_ROUTE = FALSE;
## IO Devices constraints
#### Module RS232_Uart_1 constraints
Net fpga_0_RS232_Uart_1_sin_pin LOC=J24 | IOSTANDARD=LVCMOS25;
Net fpga_0_RS232_Uart_1_sout_pin LOC=J25 | IOSTANDARD=LVCMOS25;
#### Module LEDs_8Bit constraints
Net fpga_0_LEDs_8Bit_GPIO_d_out_pin<0> LOC = AC22;
Net fpga_0_LEDs_8Bit_GPIO_d_out_pin<1> LOC = AC24;
Net fpga_0_LEDs_8Bit_GPIO_d_out_pin<2> LOC = AE22;
Net fpga_0_LEDs_8Bit_GPIO_d_out_pin<3> LOC = AE23;
Net fpga_0_LEDs_8Bit_GPIO_d_out_pin<4> LOC = AB23;
Net fpga_0_LEDs_8Bit_GPIO_d_out_pin<5> LOC = AG23;
Net fpga_0_LEDs_8Bit_GPIO_d_out_pin<6> LOC = AE24;
Net fpga_0_LEDs_8Bit_GPIO_d_out_pin<7> LOC = AD24;
Net fpga_0_LEDs_8Bit_GPIO_d_out_pin<*> IOSTANDARD=LVCMOS25;
#### Module LEDs_Positions_GPIO constraints
Net fpga_0_LEDs_Positions_GPIO_IO_pin<0> LOC=AP24;
Net fpga_0_LEDs_Positions_GPIO_IO_pin<1> LOC=AD21;
Net fpga_0_LEDs_Positions_GPIO_IO_pin<2> LOC=AH28;
Net fpga_0_LEDs_Positions_GPIO_IO_pin<3> LOC=AE21;
Net fpga_0_LEDs_Positions_GPIO_IO_pin<4> LOC=AH27;
Net fpga_0_LEDs_Positions_GPIO_IO_pin<*> IOSTANDARD=LVCMOS15;
#### Module Push_Buttons_GPIO constraints
#GPIO PB Center
Net fpga_0_Push_Buttons_5Bit_GPIO_IO_pin<0> LOC = G26;
#GPIO PB West
Net fpga_0_Push_Buttons_5Bit_GPIO_IO_pin<1> LOC = H17;
#GPIO PB South
Net fpga_0_Push_Buttons_5Bit_GPIO_IO_pin<2> LOC = A18;
#GPIO PB East
Net fpga_0_Push_Buttons_5Bit_GPIO_IO_pin<3> LOC = G17;
#GPIO PB North
Net fpga_0_Push_Buttons_5Bit_GPIO_IO_pin<4> LOC = A19;
Net fpga_0_Push_Buttons_5Bit_GPIO_IO_pin<*> IOSTANDARD=SSTL15_T_DCI;
#### Module SysACE_CompactFlash constraints
#### Module DIP_Switches_4Bit constraints
Net fpga_0_DIP_Switches_8Bit_GPIO_IO_I_pin<0> LOC=D22;
Net fpga_0_DIP_Switches_8Bit_GPIO_IO_I_pin<1> LOC=C22;
Net fpga_0_DIP_Switches_8Bit_GPIO_IO_I_pin<2> LOC=L21;
Net fpga_0_DIP_Switches_8Bit_GPIO_IO_I_pin<3> LOC=L20;
Net fpga_0_DIP_Switches_8Bit_GPIO_IO_I_pin<4> LOC=C18;
Net fpga_0_DIP_Switches_8Bit_GPIO_IO_I_pin<5> LOC=B18;
Net fpga_0_DIP_Switches_8Bit_GPIO_IO_I_pin<6> LOC=K22;
Net fpga_0_DIP_Switches_8Bit_GPIO_IO_I_pin<7> LOC=K21;
Net fpga_0_DIP_Switches_8Bit_GPIO_IO_I_pin<*> IOSTANDARD = SSTL15;
# Temporary Constraints
# Leave here until we cleanup reset timing
disable = reg_sr_o;
disable = reg_sr_r;
# Constrain BUFR clocks used to synchronize data from IOB to fabric logic
# Note that ISE cannot infer this from other PERIOD constraints because
# of the use of OSERDES blocks in the BUFR clock generation path
NET "*/*phy_if_0/clk_rsync[*]" TNM_NET = TNM_clk_rsync;
TIMESPEC TS_clk_rsync = PERIOD "TNM_clk_rsync" 5000 ps;
# Signal to select between controller and physical layer signals. Four divided by two clock
# cycles (8 memory clock cycles) are provided by design for the signal to settle down.
# Used only by the phy modules.
INST "*/u_phy_init/u_ff_phy_init_data_sel" TNM = "TNM_PHY_INIT_SEL";
TIMESPEC "TS_MC_PHY_INIT_SEL" = FROM "TNM_PHY_INIT_SEL" TO FFS = 20000 ps; // mem clock period * 8 or Clk0 period * 4
# DDR3/Status signals
NET  "fpga_0_DDR3_SDRAM_DDR3_DQ_pin[*]"                               IOSTANDARD = SSTL15_T_DCI;
NET  "fpga_0_DDR3_SDRAM_DDR3_Addr_pin[*]"                             IOSTANDARD = SSTL15;
NET  "fpga_0_DDR3_SDRAM_DDR3_BankAddr_pin[*]"                         IOSTANDARD = SSTL15;
NET  "fpga_0_DDR3_SDRAM_DDR3_RAS_n_pin"                               IOSTANDARD = SSTL15;
NET  "fpga_0_DDR3_SDRAM_DDR3_CAS_n_pin"                               IOSTANDARD = SSTL15;
NET  "fpga_0_DDR3_SDRAM_DDR3_WE_n_pin"                                IOSTANDARD = SSTL15;
NET  "fpga_0_DDR3_SDRAM_DDR3_Reset_n_pin"                             IOSTANDARD = SSTL15;
NET  "fpga_0_DDR3_SDRAM_DDR3_CS_n_pin[*]"                             IOSTANDARD = SSTL15;
NET  "fpga_0_DDR3_SDRAM_DDR3_ODT_pin[*]"                              IOSTANDARD = SSTL15;
NET  "fpga_0_DDR3_SDRAM_DDR3_CE_pin[*]"                               IOSTANDARD = SSTL15;
NET  "fpga_0_DDR3_SDRAM_DDR3_DM_pin[*]"                               IOSTANDARD = SSTL15;
NET  "fpga_0_DDR3_SDRAM_DDR3_DQS_pin[*]"                              IOSTANDARD = DIFF_SSTL15_T_DCI;
NET  "fpga_0_DDR3_SDRAM_DDR3_DQS_n_pin[*]"                            IOSTANDARD = DIFF_SSTL15_T_DCI;
NET  "fpga_0_DDR3_SDRAM_DDR3_Clk_pin[*]"                              IOSTANDARD = DIFF_SSTL15_T_DCI;
NET  "fpga_0_DDR3_SDRAM_DDR3_Clk_n_pin[*]"                            IOSTANDARD = DIFF_SSTL15_T_DCI;
# Location Constraints
# Banks specified in the comments may no longer be valid
NET  "fpga_0_DDR3_SDRAM_DDR3_DQ_pin[0]"                                LOC = "J11" ;          #Bank 26
NET  "fpga_0_DDR3_SDRAM_DDR3_DQ_pin[1]"                                LOC = "E13" ;          #Bank 26
NET  "fpga_0_DDR3_SDRAM_DDR3_DQ_pin[2]"                                LOC = "F13" ;          #Bank 26
NET  "fpga_0_DDR3_SDRAM_DDR3_DQ_pin[3]"                                LOC = "K11" ;          #Bank 26
NET  "fpga_0_DDR3_SDRAM_DDR3_DQ_pin[4]"                                LOC = "L11" ;          #Bank 26
NET  "fpga_0_DDR3_SDRAM_DDR3_DQ_pin[5]"                                LOC = "K13" ;          #Bank 26
NET  "fpga_0_DDR3_SDRAM_DDR3_DQ_pin[6]"                                LOC = "K12" ;          #Bank 26
NET  "fpga_0_DDR3_SDRAM_DDR3_DQ_pin[7]"                                LOC = "D11" ;          #Bank 26
NET  "fpga_0_DDR3_SDRAM_DDR3_DQ_pin[8]"                                LOC = "M13" ;          #Bank 26
NET  "fpga_0_DDR3_SDRAM_DDR3_DQ_pin[9]"                                LOC = "J14" ;          #Bank 26
NET  "fpga_0_DDR3_SDRAM_DDR3_DQ_pin[10]"                               LOC = "B13" ;          #Bank 26
NET  "fpga_0_DDR3_SDRAM_DDR3_DQ_pin[11]"                               LOC = "B12" ;          #Bank 26
NET  "fpga_0_DDR3_SDRAM_DDR3_DQ_pin[12]"                               LOC = "G10" ;          #Bank 26
NET  "fpga_0_DDR3_SDRAM_DDR3_DQ_pin[13]"                               LOC = "M11" ;          #Bank 26
NET  "fpga_0_DDR3_SDRAM_DDR3_DQ_pin[14]"                               LOC = "C12" ;          #Bank 26
NET  "fpga_0_DDR3_SDRAM_DDR3_DQ_pin[15]"                               LOC = "A11" ;          #Bank 26
NET  "fpga_0_DDR3_SDRAM_DDR3_DQ_pin[16]"                               LOC = "G11" ;          #Bank 26
NET  "fpga_0_DDR3_SDRAM_DDR3_DQ_pin[17]"                               LOC = "F11" ;          #Bank 26
NET  "fpga_0_DDR3_SDRAM_DDR3_DQ_pin[18]"                               LOC = "D14" ;          #Bank 26
NET  "fpga_0_DDR3_SDRAM_DDR3_DQ_pin[19]"                               LOC = "C14" ;          #Bank 26
NET  "fpga_0_DDR3_SDRAM_DDR3_DQ_pin[20]"                               LOC = "G12" ;          #Bank 26
NET  "fpga_0_DDR3_SDRAM_DDR3_DQ_pin[21]"                               LOC = "G13" ;          #Bank 26
NET  "fpga_0_DDR3_SDRAM_DDR3_DQ_pin[22]"                               LOC = "F14" ;          #Bank 26
NET  "fpga_0_DDR3_SDRAM_DDR3_DQ_pin[23]"                               LOC = "H14" ;          #Bank 26
NET  "fpga_0_DDR3_SDRAM_DDR3_DQ_pin[24]"                               LOC = "D26" ;          #Bank 36
NET  "fpga_0_DDR3_SDRAM_DDR3_DQ_pin[25]"                               LOC = "F26" ;          #Bank 36
NET  "fpga_0_DDR3_SDRAM_DDR3_DQ_pin[26]"                               LOC = "B26" ;          #Bank 36
NET  "fpga_0_DDR3_SDRAM_DDR3_DQ_pin[27]"                               LOC = "E26" ;          #Bank 36
NET  "fpga_0_DDR3_SDRAM_DDR3_DQ_pin[28]"                               LOC = "C24" ;          #Bank 36
NET  "fpga_0_DDR3_SDRAM_DDR3_DQ_pin[29]"                               LOC = "D25" ;          #Bank 36
NET  "fpga_0_DDR3_SDRAM_DDR3_DQ_pin[30]"                               LOC = "D27" ;          #Bank 36
NET  "fpga_0_DDR3_SDRAM_DDR3_DQ_pin[31]"                               LOC = "C25" ;          #Bank 36
NET  "fpga_0_DDR3_SDRAM_DDR3_Addr_pin[12]"                             LOC = "H15" ;          #Bank 25
NET  "fpga_0_DDR3_SDRAM_DDR3_Addr_pin[11]"                             LOC = "M15" ;          #Bank 25
NET  "fpga_0_DDR3_SDRAM_DDR3_Addr_pin[10]"                             LOC = "M16" ;          #Bank 25
NET  "fpga_0_DDR3_SDRAM_DDR3_Addr_pin[9]"                              LOC = "F15" ;          #Bank 25
NET  "fpga_0_DDR3_SDRAM_DDR3_Addr_pin[8]"                              LOC = "G15" ;          #Bank 25
NET  "fpga_0_DDR3_SDRAM_DDR3_Addr_pin[7]"                              LOC = "B15" ;          #Bank 25
NET  "fpga_0_DDR3_SDRAM_DDR3_Addr_pin[6]"                              LOC = "A15" ;          #Bank 25
NET  "fpga_0_DDR3_SDRAM_DDR3_Addr_pin[5]"                              LOC = "J17" ;          #Bank 25
NET  "fpga_0_DDR3_SDRAM_DDR3_Addr_pin[4]"                              LOC = "D16" ;          #Bank 25
NET  "fpga_0_DDR3_SDRAM_DDR3_Addr_pin[3]"                              LOC = "E16" ;          #Bank 25
NET  "fpga_0_DDR3_SDRAM_DDR3_Addr_pin[2]"                              LOC = "B16" ;          #Bank 25
NET  "fpga_0_DDR3_SDRAM_DDR3_Addr_pin[1]"                              LOC = "A16" ;          #Bank 25
NET  "fpga_0_DDR3_SDRAM_DDR3_Addr_pin[0]"                              LOC = "L14" ;          #Bank 25
NET  "fpga_0_DDR3_SDRAM_DDR3_BankAddr_pin[2]"                                LOC = "L15" ;          #Bank 25
NET  "fpga_0_DDR3_SDRAM_DDR3_BankAddr_pin[1]"                                LOC = "J19" ;          #Bank 25
NET  "fpga_0_DDR3_SDRAM_DDR3_BankAddr_pin[0]"                                LOC = "K19" ;          #Bank 25
NET  "fpga_0_DDR3_SDRAM_DDR3_RAS_n_pin"                                LOC = "L19" ;          #Bank 25
NET  "fpga_0_DDR3_SDRAM_DDR3_CAS_n_pin"                                LOC = "C17" ;          #Bank 25
NET  "fpga_0_DDR3_SDRAM_DDR3_WE_n_pin"                                 LOC = "B17" ;          #Bank 25
NET  "fpga_0_DDR3_SDRAM_DDR3_Reset_n_pin"                              LOC = "E18" ;          #Bank 25
NET  "fpga_0_DDR3_SDRAM_DDR3_CS_n_pin[0]"                              LOC = "K18" ;          #Bank 25
NET  "fpga_0_DDR3_SDRAM_DDR3_ODT_pin[0]"                               LOC = "F18" ;          #Bank 25
NET  "fpga_0_DDR3_SDRAM_DDR3_CE_pin[0]"                               LOC = "M18" ;          #Bank 25
NET  "fpga_0_DDR3_SDRAM_DDR3_DM_pin[0]"                                LOC = "E11" ;          #Bank 26
NET  "fpga_0_DDR3_SDRAM_DDR3_DM_pin[1]"                                LOC = "B11" ;          #Bank 26
NET  "fpga_0_DDR3_SDRAM_DDR3_DM_pin[2]"                                LOC = "E14" ;          #Bank 26
NET  "fpga_0_DDR3_SDRAM_DDR3_DM_pin[3]"                                LOC = "A26" ;          #Bank 36
NET  "fpga_0_DDR3_SDRAM_DDR3_DQS_pin[0]"                               LOC = "D12" ;          #Bank 26
NET  "fpga_0_DDR3_SDRAM_DDR3_DQS_n_pin[0]"                             LOC = "E12" ;          #Bank 26
NET  "fpga_0_DDR3_SDRAM_DDR3_DQS_pin[1]"                               LOC = "H12" ;          #Bank 26
NET  "fpga_0_DDR3_SDRAM_DDR3_DQS_n_pin[1]"                             LOC = "J12" ;          #Bank 26
NET  "fpga_0_DDR3_SDRAM_DDR3_DQS_pin[2]"                               LOC = "A13" ;          #Bank 26
NET  "fpga_0_DDR3_SDRAM_DDR3_DQS_n_pin[2]"                             LOC = "A14" ;          #Bank 26
NET  "fpga_0_DDR3_SDRAM_DDR3_DQS_pin[3]"                               LOC = "B25" ;          #Bank 36
NET  "fpga_0_DDR3_SDRAM_DDR3_DQS_n_pin[3]"                             LOC = "A25" ;          #Bank 36
NET  "fpga_0_DDR3_SDRAM_DDR3_Clk_pin[0]"                                LOC = "G18" ;          #Bank 25
NET  "fpga_0_DDR3_SDRAM_DDR3_Clk_n_pin[0]"                              LOC = "H18" ;          #Bank 25
# MMCM Location Constraints
#  modified by rong
#INST "clock_generator_0/clock_generator_0/Using_MMCM0.MMCM0_INST/MMCM_INST/MMCM_ADV_inst" LOC = "MMCM_ADV_X0Y9";
INST "*/clock_generator_0/clock_generator_0/Using_MMCM0.MMCM0_INST/MMCM_INST/MMCM_ADV_inst" LOC = "MMCM_ADV_X0Y9";
INST "*/u_mmcm_clk_base" LOC = "MMCM_ADV_X0Y8";
# Capture Clock Constraints
# Available sites are:
#  Bank 35:
#    C13:  IO_L11P_SRCC_35 : X2Y137 : CPT[0]
#    M12:  IO_L10P_MRCC_35 : X2Y139 : RSYNC[0]
#    L13:  IO_L9P_MRCC_35  : X2Y141 : CPT[1]
#    K14:  IO_L8P_SRCC_35  : X2Y143 : CPT[2]
#  Bank 26:
#    F21:  IO_L10P_MRCC_26 : X1Y179 : CPT[3]
#    B20:  IO_L9P_MRCC_26  : X1Y181 : CPT[4]
#    F19:  IO_L8P_SRCC_26  : X1Y183 :
#  Bank 25:
#    F25:  IO_L11P_SRCC_25 : X1Y137 : CPT[5]
#    C29:  IO_L10P_MRCC_25 : X1Y139 : RSYNC[1]
#    C28:  IO_L9P_MRCC_25  : X1Y141 : CPT[6]
#    D24:  IO_L8P_SRCC_25  : X1Y143 : CPT[7]
# Place RSYNC OSERDES and IODELAY:
# CLK_RSYNC[0]: Site M12
INST "*/u_phy_rdclk_gen/gen_loop_col0.u_oserdes_rsync"
  LOC = "OLOGIC_X2Y139";
INST "*/u_phy_rdclk_gen/gen_loop_col0.u_odelay_rsync"
  LOC = "IODELAY_X2Y139";
INST "*/u_phy_rdclk_gen/gen_loop_col0.u_bufr_rsync"
  LOC = "BUFR_X2Y6";
# CLK_RSYNC[1]: Site C29
INST "*/u_phy_rdclk_gen/gen_loop_col1.u_oserdes_rsync"
  LOC = "OLOGIC_X1Y139";
INST "*/u_phy_rdclk_gen/gen_loop_col1.u_odelay_rsync"
  LOC = "IODELAY_X1Y139";
INST "*/u_phy_rdclk_gen/gen_loop_col1.u_bufr_rsync"
  LOC = "BUFR_X1Y6";
# Place CPT OSERDES and IODELAY:
# DQS[0]: Site C13
INST "*/u_phy_rdclk_gen/gen_ck_cpt[0].u_oserdes_cpt"
  LOC = "OLOGIC_X2Y137";
INST "*/u_phy_rdclk_gen/gen_ck_cpt[0].u_odelay_cpt"
  LOC = "IODELAY_X2Y137";
# DQS[1]: Site L13
INST "*/u_phy_rdclk_gen/gen_ck_cpt[1].u_oserdes_cpt"
  LOC = "OLOGIC_X2Y141";
INST "*/u_phy_rdclk_gen/gen_ck_cpt[1].u_odelay_cpt"
  LOC = "IODELAY_X2Y141";
# DQS[2]: Site K14
INST "*/u_phy_rdclk_gen/gen_ck_cpt[2].u_oserdes_cpt"
  LOC = "OLOGIC_X2Y143";
INST "*/u_phy_rdclk_gen/gen_ck_cpt[2].u_odelay_cpt"
  LOC = "IODELAY_X2Y143";
# DQS[3]: Site F25
INST "*/u_phy_rdclk_gen/gen_ck_cpt[3].u_oserdes_cpt"
  LOC = "OLOGIC_X1Y137";
INST "*/u_phy_rdclk_gen/gen_ck_cpt[3].u_odelay_cpt"
  LOC = "IODELAY_X1Y137";
# OCB Monitor Constraints
# Site J10
INST "*/gen_enable_ocb_mon.u_phy_ocb_mon_top/u_oserdes_ocb_mon"
  LOC = "OLOGIC_X2Y130";
# DCI Cascading
CONFIG DCI_CASCADE = "26 25";
CONFIG DCI_CASCADE = "36 35";
# Debug Constraints
# Temporary workaround to prevent tools from performing timing analysis on
# ck_p/ck_n feedback path through the MMCM to the MMCM.LOCK signal (which in
# turn is in reset logic within the CLB fabric). This analysis is not
# necessary because the MMCM.LOCK signal is synchronized to the BUFG clock
# before being used.
NET "fpga_0_DDR3_SDRAM_DDR3_Clk_pin[*]"   TIG;
NET "fpga_0_DDR3_SDRAM_DDR3_Clk_n_pin[*]" TIG;
#### Module Hard_Ethernet_MAC constraints
Net fpga_0_Hard_Ethernet_MAC_TemacPhy_RST_n_pin LOC=AH13;
Net fpga_0_Hard_Ethernet_MAC_TemacPhy_RST_n_pin IOSTANDARD = LVCMOS25;
Net fpga_0_Hard_Ethernet_MAC_TemacPhy_RST_n_pin TIG;
Net fpga_0_Hard_Ethernet_MAC_GMII_TXD_0_pin<0> LOC=AM11;
Net fpga_0_Hard_Ethernet_MAC_GMII_TXD_0_pin<0> IOSTANDARD = LVCMOS25;
Net fpga_0_Hard_Ethernet_MAC_GMII_TXD_0_pin<1> LOC=AL11;
Net fpga_0_Hard_Ethernet_MAC_GMII_TXD_0_pin<1> IOSTANDARD = LVCMOS25;
Net fpga_0_Hard_Ethernet_MAC_GMII_TXD_0_pin<2> LOC=AG10;
Net fpga_0_Hard_Ethernet_MAC_GMII_TXD_0_pin<2> IOSTANDARD = LVCMOS25;
Net fpga_0_Hard_Ethernet_MAC_GMII_TXD_0_pin<3> LOC=AG11;
Net fpga_0_Hard_Ethernet_MAC_GMII_TXD_0_pin<3> IOSTANDARD = LVCMOS25;
Net fpga_0_Hard_Ethernet_MAC_GMII_TXD_0_pin<4> LOC=AL10;
Net fpga_0_Hard_Ethernet_MAC_GMII_TXD_0_pin<4> IOSTANDARD = LVCMOS25;
Net fpga_0_Hard_Ethernet_MAC_GMII_TXD_0_pin<5> LOC=AM10;
Net fpga_0_Hard_Ethernet_MAC_GMII_TXD_0_pin<5> IOSTANDARD = LVCMOS25;
Net fpga_0_Hard_Ethernet_MAC_GMII_TXD_0_pin<6> LOC=AE11;
Net fpga_0_Hard_Ethernet_MAC_GMII_TXD_0_pin<6> IOSTANDARD = LVCMOS25;
Net fpga_0_Hard_Ethernet_MAC_GMII_TXD_0_pin<7> LOC=AF11;
Net fpga_0_Hard_Ethernet_MAC_GMII_TXD_0_pin<7> IOSTANDARD = LVCMOS25;
Net fpga_0_Hard_Ethernet_MAC_GMII_TX_EN_0_pin LOC=AJ10;
Net fpga_0_Hard_Ethernet_MAC_GMII_TX_EN_0_pin IOSTANDARD = LVCMOS25;
Net fpga_0_Hard_Ethernet_MAC_GMII_TX_ER_0_pin LOC=AH10;
Net fpga_0_Hard_Ethernet_MAC_GMII_TX_ER_0_pin IOSTANDARD = LVCMOS25;
Net fpga_0_Hard_Ethernet_MAC_GMII_TX_CLK_0_pin LOC=AH12;
Net fpga_0_Hard_Ethernet_MAC_GMII_TX_CLK_0_pin IOSTANDARD = LVCMOS25;
Net fpga_0_Hard_Ethernet_MAC_GMII_RXD_0_pin<0> LOC=AN13;
Net fpga_0_Hard_Ethernet_MAC_GMII_RXD_0_pin<0> IOSTANDARD = LVCMOS25;
Net fpga_0_Hard_Ethernet_MAC_GMII_RXD_0_pin<1> LOC=AF14;
Net fpga_0_Hard_Ethernet_MAC_GMII_RXD_0_pin<1> IOSTANDARD = LVCMOS25;
Net fpga_0_Hard_Ethernet_MAC_GMII_RXD_0_pin<2> LOC=AE14;
Net fpga_0_Hard_Ethernet_MAC_GMII_RXD_0_pin<2> IOSTANDARD = LVCMOS25;
Net fpga_0_Hard_Ethernet_MAC_GMII_RXD_0_pin<3> LOC=AN12;
Net fpga_0_Hard_Ethernet_MAC_GMII_RXD_0_pin<3> IOSTANDARD = LVCMOS25;
Net fpga_0_Hard_Ethernet_MAC_GMII_RXD_0_pin<4> LOC=AM12;
Net fpga_0_Hard_Ethernet_MAC_GMII_RXD_0_pin<4> IOSTANDARD = LVCMOS25;
Net fpga_0_Hard_Ethernet_MAC_GMII_RXD_0_pin<5> LOC=AD11;
Net fpga_0_Hard_Ethernet_MAC_GMII_RXD_0_pin<5> IOSTANDARD = LVCMOS25;
Net fpga_0_Hard_Ethernet_MAC_GMII_RXD_0_pin<6> LOC=AC12;
Net fpga_0_Hard_Ethernet_MAC_GMII_RXD_0_pin<6> IOSTANDARD = LVCMOS25;
Net fpga_0_Hard_Ethernet_MAC_GMII_RXD_0_pin<7> LOC=AC13;
Net fpga_0_Hard_Ethernet_MAC_GMII_RXD_0_pin<7> IOSTANDARD = LVCMOS25;
Net fpga_0_Hard_Ethernet_MAC_GMII_RX_DV_0_pin LOC=AM13;
Net fpga_0_Hard_Ethernet_MAC_GMII_RX_DV_0_pin IOSTANDARD = LVCMOS25;
Net fpga_0_Hard_Ethernet_MAC_GMII_RX_ER_0_pin LOC=AG12;
Net fpga_0_Hard_Ethernet_MAC_GMII_RX_ER_0_pin IOSTANDARD = LVCMOS25;
Net fpga_0_Hard_Ethernet_MAC_GMII_RX_CLK_0_pin LOC=AP11;
Net fpga_0_Hard_Ethernet_MAC_GMII_RX_CLK_0_pin IOSTANDARD = LVCMOS25;
Net fpga_0_Hard_Ethernet_MAC_MII_TX_CLK_0_pin LOC = AD12;
Net fpga_0_Hard_Ethernet_MAC_MII_TX_CLK_0_pin IOSTANDARD = LVCMOS25;
Net fpga_0_Hard_Ethernet_MAC_MDC_0_pin LOC=AP14;
Net fpga_0_Hard_Ethernet_MAC_MDC_0_pin IOSTANDARD = LVCMOS25;
Net fpga_0_Hard_Ethernet_MAC_MDIO_0_pin LOC=AN14;
Net fpga_0_Hard_Ethernet_MAC_MDIO_0_pin IOSTANDARD = LVCMOS25;
###### Hard_Ethernet_MAC
# This is a GMII system
# GTX_CLK_0 = 125MHz
# LlinkTemac0_CLK = plb_v46 clk = host clock = 100MHz from clock generator
# Rx/Tx Client clocks are Rx/Tx PHY clocks so CORE Gen PHY clock constraints propagate to Rx/Tx client clock periods
# Time domain crossing constraints (DATAPATHONLY) are set for maximum bus frequency
# allowed by IP which is the maximum option in BSB. For lower bus frequency choice in BSB,
# the constraints are over constrained. Relaxing them for your system may reduce build time.
net "*/hrst*" TIG;
net "*/V6HARD_SYS.I_TEMAC/speed_vector_0_i*" TIG;
NET "*Hard_Ethernet_MAC*/LlinkTemac0_CLK"   TNM_NET = "LLCLK0"; #name of signal connected to TEMAC LlinkTemac0_CLK input
NET "*Hard_Ethernet_MAC*/SPLB_Clk"          TNM_NET = "PLBCLK"; #name of signal connected to TEMAC SPLB_Clk input
# CLOCK CONSTRAINTS
# The following constraints are required. If you choose to not use the example
# design level of wrapper hierarchy, the net names should be translated to
# match your design.
# Ethernet GTX_CLK high quality 125 MHz reference clock
#                      __________
# -GTX_CLK_0----------|          |
#                     | BUFGCTRL |---Tx_Cl_Clk
# -MII_TX_CLK_0-------|__________|
# Changed NET
# NET "GTX_CLK" TNM_NET = "ref_gtx_clk";
# modified by rong
# NET "Hard_Ethernet_MAC*/GTX_CLK_0"   TNM_NET = "ref_gtx_clk"; #name of signal connected to TEMAC GTX_CLK_0 input
NET "*Hard_Ethernet_MAC*/GTX_CLK_0"   TNM_NET = "ref_gtx_clk"; #name of signal connected to TEMAC GTX_CLK_0 input
TIMEGRP "v6_emac_v1_3_clk_ref_gtx" = "ref_gtx_clk";
TIMESPEC "TS_v6_emac_v1_3_clk_ref_gtx" = PERIOD "v6_emac_v1_3_clk_ref_gtx" 8 ns HIGH 50 %;
# Multiplexed 1 Gbps, 10/100 Mbps output inherits constraint from GTX_CLK
#                      __________
# Changed NET name
# NET "tx_clk" TNM_NET = "ref_mux_clk";
NET "*/Tx_Cl_Clk" TNM_NET = "ref_mux_clk";
TIMEGRP "v6_emac_v1_3_clk_ref_mux" = "ref_mux_clk";
TIMESPEC "TS_v6_emac_v1_3_clk_ref_mux" = PERIOD "v6_emac_v1_3_clk_ref_mux" TS_v6_emac_v1_3_clk_ref_gtx HIGH 50%;
# Ethernet GMII PHY-side receive clock
#                      __________
# --- GMII_RX_CLK_0---|   BUFR   |---RxClientClk_0
#                     |__________|
# Changed NET name
# NET "GMII_RX_CLK" TNM_NET = "phy_clk_rx";
NET "*/RxClientClk_0" TNM_NET = "phy_clk_rx";
TIMEGRP "v6_emac_v1_3_clk_phy_rx" = "phy_clk_rx";
TIMESPEC "TS_v6_emac_v1_3_clk_phy_rx" = PERIOD "v6_emac_v1_3_clk_phy_rx" 7.5 ns HIGH 50 %;
# IDELAYCTRL 200 MHz reference clock
# Changed NET name
# NET "REFCLK" TNM_NET  = "clk_ref_clk";
NET "*/REFCLK" TNM_NET  = "clk_ref_clk";
TIMEGRP "ref_clk" = "clk_ref_clk";
TIMESPEC "TS_ref_clk" = PERIOD "ref_clk" 5 ns HIGH 50 %;
# Constrain the DCR interface clock to an example frequency of 100 MHz
# Changed NET name
# NET "DCREMACCLK" TNM_NET = "host_clock";
NET "*/SPLB_Clk" TNM_NET = "host_clock";
TIMEGRP "clk_host" = "host_clock";
TIMESPEC "TS_clk_host" = PERIOD "clk_host" 10 ns HIGH 50 %;
# PHYSICAL INTERFACE CONSTRAINTS
# The following constraints are necessary for proper operation, and are tuned
# for this example design. They should be modified to suit your design.
# GMII physical interface constraints
# Set the IDELAY values on the PHY inputs, tuned for this example design.
# These values should be modified to suit your design.
INST "*gmii*ideldv"    IDELAY_VALUE = 30;
INST "*gmii*ideld0"    IDELAY_VALUE = 25;
INST "*gmii*ideld1"    IDELAY_VALUE = 31;
INST "*gmii*ideld2"    IDELAY_VALUE = 31;
INST "*gmii*ideld3"    IDELAY_VALUE = 27;
INST "*gmii*ideld4"    IDELAY_VALUE = 29;
INST "*gmii*ideld5"    IDELAY_VALUE = 31;
INST "*gmii*ideld6"    IDELAY_VALUE = 31;
INST "*gmii*ideld7"    IDELAY_VALUE = 31;
INST "*gmii*ideler"    IDELAY_VALUE = 22;
#  This signal trace is longer than the clock trace, and arrives at the FPGA pin ~65 ps after the clock
#  Therefore the offset in constraint must have less setup time than nominal
NET fpga_0_Hard_Ethernet_MAC_GMII_RXD_0_pin[0] OFFSET = IN 2.435 ns VALID 3 ns BEFORE "fpga_0_Hard_Ethernet_MAC_GMII_RX_CLK_0_pin";
#  This signal trace is shorter than the clock trace, and arrives at the FPGA pin ~375 ps before the clock
#  Therefore the offset in constraint must have more setup time than nominal
NET fpga_0_Hard_Ethernet_MAC_GMII_RXD_0_pin[1] OFFSET = IN 2.875 ns VALID 3 ns BEFORE "fpga_0_Hard_Ethernet_MAC_GMII_RX_CLK_0_pin";
#  This signal trace is shorter than the clock trace, and arrives at the FPGA pin ~372 ps before the clock
NET fpga_0_Hard_Ethernet_MAC_GMII_RXD_0_pin[2] OFFSET = IN 2.872 ns VALID 3 ns BEFORE "fpga_0_Hard_Ethernet_MAC_GMII_RX_CLK_0_pin";
#  This signal trace is shorter than the clock trace, and arrives at the FPGA pin ~115 ps before the clock
NET fpga_0_Hard_Ethernet_MAC_GMII_RXD_0_pin[3] OFFSET = IN 2.615 ns VALID 3 ns BEFORE "fpga_0_Hard_Ethernet_MAC_GMII_RX_CLK_0_pin";
#  This signal trace is shorter than the clock trace, and arrives at the FPGA pin ~244 ps before the clock
NET fpga_0_Hard_Ethernet_MAC_GMII_RXD_0_pin[4] OFFSET = IN 2.744 ns VALID 3 ns BEFORE "fpga_0_Hard_Ethernet_MAC_GMII_RX_CLK_0_pin";
#  This signal trace is shorter than the clock trace, and arrives at the FPGA pin ~404 ps before the clock
NET fpga_0_Hard_Ethernet_MAC_GMII_RXD_0_pin[5] OFFSET = IN 2.904 ns VALID 3 ns BEFORE "fpga_0_Hard_Ethernet_MAC_GMII_RX_CLK_0_pin";
#  This signal trace is shorter than the clock trace, and arrives at the FPGA pin ~498 ps before the clock
NET fpga_0_Hard_Ethernet_MAC_GMII_RXD_0_pin[6] OFFSET = IN 2.998 ns VALID 3 ns BEFORE "fpga_0_Hard_Ethernet_MAC_GMII_RX_CLK_0_pin";
#  This signal trace is shorter than the clock trace, and arrives at the FPGA pin ~485 ps before the clock
NET fpga_0_Hard_Ethernet_MAC_GMII_RXD_0_pin[7] OFFSET = IN 2.985 ns VALID 3 ns BEFORE "fpga_0_Hard_Ethernet_MAC_GMII_RX_CLK_0_pin";
#  This signal trace is shorter than the clock trace, and arrives at the FPGA pin ~291 ps before the clock
NET fpga_0_Hard_Ethernet_MAC_GMII_RX_DV_0_pin  OFFSET = IN 2.791 ns VALID 3 ns BEFORE "fpga_0_Hard_Ethernet_MAC_GMII_RX_CLK_0_pin";
#  This signal trace is longer than the clock trace, and arrives at the FPGA pin ~308 ps after the clock
NET fpga_0_Hard_Ethernet_MAC_GMII_RX_ER_0_pin  OFFSET = IN 2.192 ns VALID 3 ns BEFORE "fpga_0_Hard_Ethernet_MAC_GMII_RX_CLK_0_pin";
# Constrain the GMII physical interface flip-flops to IOBs
# Changed from 'true' to 'force'
INST "*gmii?RXD_TO_MAC*"  IOB = force;
INST "*gmii?RX_DV_TO_MAC" IOB = force;
INST "*gmii?RX_ER_TO_MAC" IOB = force;
INST "*gmii?GMII_TXD_?"   IOB = force;
INST "*gmii?GMII_TX_EN"   IOB = force;
INST "*gmii?GMII_TX_ER"   IOB = force;
TIMESPEC "TS_LL_CLK0_2_RX_CLIENT_CLK0"  = FROM LLCLK0 TO phy_clk_rx  8000 ps DATAPATHONLY; #constant value based on Ethernet clock
TIMESPEC "TS_LL_CLK0_2_TX_CLIENT_CLK0"  = FROM LLCLK0 TO ref_mux_clk 8000 ps DATAPATHONLY; #constant value based on Ethernet clock
TIMESPEC "TS_RX_CLIENT_CLK0_2_LL_CLK0"  = FROM phy_clk_rx  TO LLCLK0 10000 ps DATAPATHONLY; #varies based on period of LocalLink clock
TIMESPEC "TS_TX_CLIENT_CLK0_2_LL_CLK0"  = FROM ref_mux_clk TO LLCLK0 10000 ps DATAPATHONLY; #varies based on period of LocalLink clock
// UCF FILE done
songxin
0
Re: "WARNING:ConstraintSystem:203"
Pls Somebody help me !
I'm stuck at this problem for almost a week.
Expert Contributor
eteam00
0
[ Edited ]
Open a webcase for direct support from Xilinx.
-- Bob Elkind
SIGNATURE:
Summary:
songxin
0
Thanks. I'll do it right now!
grossfriedrich
0
i have the same Problem. Is there any Solution?
Super Contributor
ankury
0
have a look at this AR http://www.xilinx.com/support/answers/34900.htm .
you will get info to resolve thids issue
sauravs
0
This is caused by duplicate locate constraints (or LOC constraints) being placed in the UCF.
Remove the duplicates to remove this warning.
For example, this UCF would have:
  INST "my_module/my_logic" LOC=SLICE_X0Y84;
To fix the problem remove a duplicate:
  # INST "my_module/my_logic" LOC=SLICE_X0Y84;
regards,
saurav
