Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
rfjhh
0
Accepted Solution
Environment variable 'Temp' error (Windows 7, 32 bit)
I'm using ISE Design Suite 14.1 (windows 7, 32 bit) and an error appears:
"Environment variable 'TEMP' not defined or points at a non-existant directory or a non-writable directory. Please define it to a directory location for temporary files."
I've created C:\TEMP directory but the problem still exists.
What can I do?
bwiec
0
Re: Environment variable 'Temp' error (Windows 7, 32 bit)
Have you actually created an environment variable to point to that directory?
www.xilinx.com
rfjhh
0
Non. How can I do it??
bwiec
0
First google result:
http://www.itechtalk.com/thread3595.html
You may want to check first... you likely already have TEMP and TMP variables, but they may not be pointing to a good location that you're trying to accomplish.
www.xilinx.com
rfjhh
0
Yes, I have already TEMP and TMP variables and they point to "%USERPROFILE%\AppData\Local\Temp" as indicated in the tutorial "How to Add, Remove or Edit Environment variables in Windows 7?", so I think I havo to do something in ISE.
rfjhh
0
Do you have a chat service or something like that in order to get a faster response?
graces
0
Try cleanup project files and rerun.
This could be an occasional issue.
rfjhh
0
The problem has been fixed. Kaspersky had sent two files in quarentine. Yesterday they was returned to be restored and ISE was started to run well.
ghs
ghs
0
Could you tell us which files Kaspersky quarantined?
We are having the same problem, and we're running Kaspersky KES8 but I am not seeing anything in the quarantine.
deanmiller
0
Re: Environment variable 'Temp' error (Windows 7, 32 bit) (Also Windows XP)
This has been plaguing me for come time, but I think I have found the cause and the solution.
The environment I have is Windows XP SP3. I run Kaspersky AV but do not believe that is at all involved in the matter.
I have been running into this during implementation using ISE 13.4.  Sometimes ISE would stop in translate, sometimes it would stop in place & route.  And sometimes it would (after rebooting the machine) run to completion.
One thing that seemed to help for a week or so was to run regedit and in
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Lsa
change forceguest to 0.
But today that failed to help.  forceguest was 0 but I simply could not run ISE to completion.
What did seem to solve it was to run a registry cleaner (I use and recommend Advanced System Optimizer 3 Registry Cleaner from SysTweak.  It's not free but I believe you get what you pay for.)  Make sure that all of the registry scan settings are turned on, particularly "Deep Scan."  This found some problems involving C:\temp!  After cleaning the registry the problem (at least for now) went away.
I also have a /system/ environment variable TEMP = C:\TEMP.
Hope this helps!
