- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Installati on drivers for USB cable 14.1
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-07-2012 12:33 AM
We installed the 14.1 version of ISE design suite. The tools seems to work fine however the drivers dor the Platform Cable USB II can't be installed. We tried by automatic installation (plug the cable into a USB port and follow the instructions) and downloading and installing directly the specific driver but nothing works. We always have a "unkown driver" message when pluging the cable.
We are using:
- Microsoft Windows XP
- Professionnel
- Version 2002
- Service Pack 3
With the configuration :
- Intel® Core™2 Duo CPU
- E6550 @ 2.33GHz
- 2.33 Ghz, 3.48 Go de RAM
Does anyone have the same issues ?
Re: Installati on drivers for USB cable 14.1
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-07-2012 10:06 PM
We are using:
- Professionnel
- Version 2002
- Service Pack 3
- E6550 @ 2.33GHz
Try by rebooting your system and make sure that your board is on.
then you have to plug your usb cable into your systems usb port.
Probably it will ask you for 3 times to install the driver for new system.
After it is done try rebooting your system.If still shows the same error then check with different usb cable ?
Signature:
1.Have you ever tried typing your question into Google? If not you should before posting.
2.Read the datasheet and user guide. Have you read the user guide in detail ? Can you find the user guide?
3. Search the forums for similar topics.
4.I have neither found any similar thread in existing forum nor web-search is helpful to me.What should I do ?
Post your issue in detail comprehensive format on the relevant
forum.
5. Do not post the same question on multiple forums,please search and post it on relevant forum.
6. Do not raise a new topic or question on someone else's thread, start a new thread!
7. Students/Newbies: Copying code is not the same as learning to design.
8. "It does not work" is not a question which can be answered. Provide much details (with webaddress, datasheet links,etc..).
and make sure to be specific!
9. You are not charged extra fees for comments in your code,It will help others to understand well.
10.If someone answers your question, mark the post with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left).
