- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Installing usb cable driver (ubuntu)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
10-01-2009 06:45 AM
I know that ubuntu is not a supported operating system but it is possible to get the cable driver working.
I am running the ./install_drivers script that Xilinx provides and am receiving errors when it gets to windrvr6. I am not a linux guru so the output doesn't mean very much but I suspect I am missing some library or maybe something is not linked properly. Could someone comment on the compile errors or offer a suggestion for me to try? Is there some library I must install? I think it is strange that the source code exists but fails to compile due to what looks like syntax errors. I don't want to give up because last time I tried this a few months ago, on the same operating system, the programming cable worked perfectly.
I am using:
ubuntu 9.04
gcc/g++ 4.3 (have tried 4.1 if that matters)
bash
Also installed:
libusb-dev
fxload
--Installing windrvr6------------------------------------------
--Checking version.--File /lib/modules/2.6.28-15-generic/kernel/drivers/misc
--File LINUX.2.6.28-15-generic.i386/windrvr6.ko does not exist.
--Setting source version to 900.
--File LINUX.2.6.28-15-generic.i386/windrvr6.ko is newer than the destination file.
loading cache ./config.cache
checking for cpu architecture... i386
checking for WinDriver root directory... /home/borko/Desktop/install_drivers/linux_drivers/
checking for linux kernel source... found at /lib/modules/2.6.28-15-generic/build
checking for lib directory... ln -sf $(ROOT_DIR)/lib/$(SHARED_OBJECT).so /usr/lib/$(SHARED_OBJECT).so
checking which directories to include... -I/lib/modules/2.6.28-15-generic/build/include
checking linux kernel version... 2.6.28-15-generic
checking for modules installation directory... /lib/modules/2.6.28-15-generic/kernel/drivers/misc
checking for gcc kernel version... 4
checking output directory... LINUX.2.6.28-15-generic.i386
checking target... LINUX.2.6.28-15-generic.i386/windrvr6.ko
checking for usb support... yes
checking for regparm kernel option... 1
checking for right linked object... windrvr_gcc_v3_regparm.a
checking for modpost location... /lib/modules/2.6.28-15-generic/build/scripts/mod/m
checking for udev support... no
creating ./config.status
creating makefile
rm -f core LINUX.2.6.28-15-generic.i386/windrvr6.ko LINUX.2.6.28-15-generic.i386/*
cc -c -O2 -Wall -DLINUX -D__KERNEL__ -DMODULE -DWINDRIVER_KERNEL -DLINUX_USB_SUPPORT -mpreferred-stack-boundary=2 -mregparm=3 -nostdinc -iwithprefix include -Wstrict-prototypes -Wno-trigraphs -fno-common -pipe -O -I/lib/modules/2.6.28-15-generic/build/include -I/home/borko/Desktop/install_drivers/linux_driver
In file included from /lib/modules/2.6.28-15-generic/build/include/linux
from linux_wrappers.c:19:
/usr/lib/gcc/i486-linux-gnu/4.1.3/include/asm/posi
...similar compile errors for over 1000 lines
Re: Installing usb cable driver (ubuntu)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
10-21-2009 04:32 PM
I'm having a similar issue but it looks like my installation script is breaking before the point where yours does:
$~/Desktop/install_drivers$ sudo ./install_drivers
--Driver versions in this package: windrvr=900, xpc4drvr=1041
--Script name = ./install_drivers
--HostName = C3ITester
--Current working dir = /home/eric/Desktop/install_drivers
--Script location = /home/eric/Desktop/install_drivers
--Kernel version = 2.6.28-15-generic.
./install_drivers: 380: arch: not found
--Arch = .
--Installer version = 1053
--Unsetting ARCH environment variable.
./install_drivers: 384: arch: not found
--User has root permission.
--File /lib/modules/misc/install_windrvr6 does not exist.
--Installing USB drivers------------------------------------------
--Using udev.
--File /usr/share/xusbdfwu.hex exists.
./setup_pcusb: 191: Bad substitution
--File /sbin/fxload exists.
--Checking version.
./configure: 531: Syntax error: "(" unexpected
make: *** No rule to make target `clean'. Stop.
make: *** No targets specified and no makefile found. Stop.
make: *** No rule to make target `install'. Stop.
--make windrvr install rc= 2
--install_windrvr6 rc = 2
--Module windrvr6 is not running.
--Module xpc4drvr is not running.
--Note: By default, the file permission of /dev/windrvr6 is enabled for the root user only
and must be changed to allow access to other users.
--Return code = 2
I'm interested to see if we can get these cable drivers running on Ubuntu.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
10-22-2009 08:20 AM
I ran into that problem and was able to get through it by changing the shell.
Ubuntu uses something called dash by default but the install script works with bash (your error is syntax related).
You might be able to just type at the command line
> bash
then try to run the script.
I didnt do this but actually changed my default shell with the commands below:
To see that your shell is infact dash type
> ls -l /bash/sh
It should say something like sh -> /bin/dash
I fixed this by changing the symbolic link at /bin/sh with commands
> cd /bin
> sudo rm sh
> sudo ln -s bash sh
Like I said, I'm no linux expert and actually have a second windows machine for downloading bitfiles.
It bugs me because at one point in time I had the drivers working on ubuntu 9.04
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
10-22-2009 09:54 AM
I managed to get through my problem with the cable. As it turns out the Xilinx 11.1 software is able to use the Ubuntu native libusb drivers. So don't even bother trying to build the usb drivers from Xilinx unless you can't get libusb for your Ubuntu. I think they are alredy installed by default on the newest distrubutions of Ubuntu, you can try and get them by using apt-get:
apt-get install libusb-0.1-4
another handy tip:
to start chipscope you need to first start the cs_server:
/opt/Xilinx/11.1/ChipScope/bin/lin$ ./cs_server.sh
then start chipscope in another terminal:
/opt/Xilinx/11.1/ChipScope/bin/lin$ sudo ./analyzer.sh
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
12-15-2009 08:25 AM
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
12-15-2009 02:42 PM
hi dhthomas,
I used version 11.1 of the Xilinx tools on Ubuntu Jaunty Jackalope and later on Karmic Koala. What versions are you using, and could you say what the error message looks like? Also have you tried running the /opt/Xilinx/11.1/settings32.sh script?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
12-20-2009 02:55 AM
I have ISE 11.3 running in ubuntu 9.10. Look at:
http://www.george-smart.co.uk/wiki/Xilinx_JTAG_Lin
http://baylor-recomp.wikidot.com/setupxilinxtools1
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
12-22-2009 02:05 PM
Sorry, I just recently upgraded to 9.10 and I think I'm actually having the same issue you are. I was mistaken earlier when I said I had it working in 9.10. You should be able to get it working in 9.04 without trouble. Here's what I am seeing:
Welcome to iMPACT
iMPACT Version: 11.1
Project: /home/eric//auto_project.ipf created.
// *** BATCH CMD : setMode -bs
GUI --- Auto connect to cable...
// *** BATCH CMD : setCable -port auto
AutoDetecting cable. Please wait.
Reusing A0150001 key.
Reusing 24150001 key.
OS platform = i686.
Connecting to cable (Usb Port - USB21).
Checking cable driver.
File version of /opt/Xilinx/11.1/ISE/bin/lin/xusbdfwu.hex = 1030.
File version of /etc/hotplug/usb/xusbdfwu.fw/xusbdfwu.hex = 1030.
Using libusb.
Cable connection failed.
Reusing 78150001 key.
Reusing FC150001 key.
OS platform = i686.
Connecting to cable (Parallel Port - parport0).
Linux release = 2.6.31-16-generic.
WARNING:iMPACT - Module windrvr6 is not loaded. Please reinstall the cable drivers. See Answer Record 22648.
Reusing 79150001 key.
Reusing FD150001 key.
OS platform = i686.
Connecting to cable (Parallel Port - parport1).
Reusing 7A150001 key.
Reusing FE150001 key.
OS platform = i686.
Connecting to cable (Parallel Port - parport2).
Reusing 7B150001 key.
Reusing FF150001 key.
OS platform = i686.
Connecting to cable (Parallel Port - parport3).
PROGRESS_END - End Operation.
Elapsed time = 2 sec.
Cable autodetection failed.
WARNING:iMPACT:923 - Can not find cable, check cable setup !
Note where it says Using libusb and cable connection failed. It seems like it is finding the libusb driver but it isn't locating the cable for some reason. The windrvr6 error messages all seem to be associated with the parallel port.
Maybe someone with more knowlege can help us out?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
12-24-2009 10:48 PM
check the installation of libusb and fxload. then set rules for udev
sudo sed /opt/Xilinx/11.1/ISE/bin/lin/xusbdfwu.rules -e 's:TEMPNODE:tempnode:g' > /etc/udev/rules.d/xusbdfwu.rulessudo cp /opt/Xilinx/11.1/ISE/bin/lin/xusb*.hex /usr/share/
sudo /etc/init.d/udev restart
it works on ubuntu 9.10 without no problem
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
01-11-2010 08:00 AM
