- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Planahead 13.2 missing SHSMP.DLL
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-15-2012 09:14 AM
Hello everyone,
I'm having a problem running Planahead 13.2. After installing Planahead, things seemed to work okay. I've shut it down and restarted and now it won't run saying that it is missing shsmp.dll.
I later found out that I had to change the shortcut to call out the 64 bit version. After I added -m64, Planahead 64 bit ran normally. Until I shut it down and restarted it. Now it's saying shsmp64.dll is missing.
I've confirmed that both dlls are in their respective folders. Does anyone have any ideas how to get Planahead to recognize them?
Scott
Solved! Go to Solution.
Re: Planahead 13.2 missing SHSMP.DLL
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-15-2012 01:13 PM
Okay, that was strange. I tried going back to PlanAhead 32-bit and now I can't reproduce this using either version.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-17-2012 11:50 AM
Please check with the latest 14.1 version.
Signature:
1.Have you ever tried typing your question into Google? If not you should before posting.
2.Read the datasheet and user guide. Have you read the user guide in detail ? Can you find the user guide?
3. Search the forums for similar topics.
4.I have neither found any similar thread in existing forum nor web-search is helpful to me.What should I do ?
Post your issue in detail comprehensive format on the relevant
forum.
5. Do not post the same question on multiple forums,please search and post it on relevant forum.
6. Do not raise a new topic or question on someone else's thread, start a new thread!
7. Students/Newbies: Copying code is not the same as learning to design.
8. "It does not work" is not a question which can be answered. Provide much details (with webaddress, datasheet links,etc..).
and make sure to be specific!
9. You are not charged extra fees for comments in your code,It will help others to understand well.
10.If someone answers your question, mark the post with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left).
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
07-03-2012 12:35 AM
hi,
its because ur missing .dll file, it happens often, u pls copy and paste ur .dll file from a full installation m/c which is working fine or contact ur local vendor and tell them to mail u the following .dll file.
Chandrajit
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
07-03-2012 06:16 AM
Hi Chandrajit,
Thank you for your replay. The dlls are both present in the correct directories so I'm not sure what else to do. This issue has come up with the 64-bit version again but fortunately the 32-bit version seems to work.
Scott
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
07-04-2012 12:57 AM
Dear Scott,
while creating the license of ur ISE what version OPERATING SYSTEM did u select(32 or 64)?
Chandrajit
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
07-05-2012 06:25 AM
I went back and checked the licensing site and it looks like it's 32-bit. Would that block me from using the 64-bit version? The strange thing is that the 64-bit version worked the first time I used it. After I rebooted my computer, it started giving me the error.
Scott
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
07-05-2012 06:41 AM
can we have a small chat in gtalk now???
Chandrajit
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
07-13-2012 02:10 PM
I finally got to the bottom of this. If I launch PlanAhead from the start menu, it's fine. If I then pin it to the task bar (Windows 7) and relaunch it, then it gives the error.
Hope this helps.
