Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
pourya_alinezhad
0
Accepted Solution
Process "Check Syntax" failed!!?
hello
i'm new to FPGAs and programming using ise.
i have purchased a spartan-3E starter kit and the box involved ise9.1 DVD .I successfuly  licensed the software and instaled it.but when i try to check my program's sysntax the following error accurs ..
Started : "Check Syntax for counter".
ERROR:Xst:1531 - The evaluation period for this evaluation software has expired.
   Per the guidelines of the Evaluation Agreement, which was shipped to you
   along with the Evaluation CDs, this software will no longer operate.
   We are eager to assist you as you conclude your evaluation of the Xilinx
   solution. Your local Field Applications Engineer or salesperson is available
   to answer any questions or to assist you in the purchase of an annual
   software license. You may also contact Xilinx directly at eval@xilinx.com
   Thank you for evaluating the Xilinx solution. We appreciate your interest in
   Xilinx and we look forward to earning your confidence and your business.
now what do I have to do? do the Xilinx gives me new license? I don't want to use ise13 becuse ise DVD packs that i can buy ,all are cracked here! i can't reach a sutable one.
snake68
0
Re: Process "Check Syntax" failed!!?
But you did! ;)
Expert Contributor
sushantm
0
Better to call concerned persons for further investigation.
The board is to discuss technical issues/queries and not to such crap things!
I hope listener understands and follow the rules If I am not wrong!
--Sushant Mahajan
Signature:
1.Have you ever tried typing your question into Google? If not you should before posting.
2.Read the datasheet and user guide. Have you read the user guide in detail ? Can you find the user guide?
3. Search the forums for similar topics.
4.I have neither found any similar thread in existing forum nor web-search is helpful to me.What should I do ?
Post your issue in detail comprehensive format on the relevant
forum.
5. Do not post the same question on multiple forums,please search and post it on relevant forum.
6. Do not raise a new topic or question on someone else's thread, start a new thread!
7. Students/Newbies: Copying code is not the same as learning to design.
8. "It does not work" is not a question which can be answered. Provide much details (with webaddress, datasheet links,etc..).
and make sure to be specific!
9. You are not charged extra fees for comments in your code,It will help others to understand well.
10.If someone answers your question, mark the post with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left).
matthewtinsley
0
Right. You can Google th einformation and find the solution for it. Good Luck!
__________________________________
credit card and check processing company
