Re: RHEL5 64-bit ISE 13.1, PlanAhead launch from w/in ISE fails, terminal indicates rdiArgs.sh Segmentation Fault
The same problem occur with version 14.6 of the PlanAhead.
Debugging the issue I got to this point:
#0  x86_64_fallback_frame_state (fs=0x7fe1b5e63860, context=<optimized out>) at ../../../../src/lnx64/libgcc/../gcc/config/i386/linux-unwind.h:47
#1  uw_frame_state_for (fs=0x7fe1b5e63860, context=0x7fe1b5e639e0) at ../../../../src/lnx64/libgcc/../gcc/unwind-dw2.c:1145
#2  uw_frame_state_for (context=0x7fe1b5e639e0, fs=0x7fe1b5e63860) at ../../../../src/lnx64/libgcc/../gcc/unwind-dw2.c:1124
#3  0x00007fe1eb77bc9d in _Unwind_Backtrace (trace=0x7fe1eb2985f0, trace_argument=0x7fe1b5e63b10) at ../../../../src/lnx64/libgcc/../gcc/unwind.inc:290
#4  0x00007fe1eb298786 in backtrace () from /lib/x86_64-linux-gnu/libc.so.6
#5  0x00007fe1ec2808ea in HUTBackTrace::getTrace(stlp_std::basic_string<char, stlp_std::char_traits<char>, stlp_std::allocator<char> >&, unsigned long) ()
   from /opt/Xilinx/14.6/ISE_DS/PlanAhead/lib/lnx64.o/librdi_common.so
#6  0x00007fe1ec281292 in HUTBackTrace::printTrace(stlp_std::basic_ostream<char, stlp_std::char_traits<char> >&, unsigned long) () from /opt/Xilinx/14.6/ISE_DS/PlanAhead/lib/lnx64.o/librdi_common.so
#7  0x00007fe1ec281a58 in HUTBackTrace::handler(int) () from /opt/Xilinx/14.6/ISE_DS/PlanAhead/lib/lnx64.o/librdi_common.so
#8  0x00007fe1c859a749 in os::Linux::chained_handler(int, siginfo*, void*) () from /opt/Xilinx/14.6/ISE_DS/PlanAhead/tps/lnx64/jre/lib/amd64/server/libjvm.so
#9  0x00007fe1c859efb7 in JVM_handle_linux_signal () from /opt/Xilinx/14.6/ISE_DS/PlanAhead/tps/lnx64/jre/lib/amd64/server/libjvm.so
#10 <signal handler called>
#11 0x00007fe1b3246880 in ?? ()
#12 0x00007fe1eb556d92 in __nptl_deallocate_tsd () from /lib/x86_64-linux-gnu/libpthread.so.0
#13 0x00007fe1eb556f9c in start_thread () from /lib/x86_64-linux-gnu/libpthread.so.0
#14 0x00007fe1eb280e1d in clone () from /lib/x86_64-linux-gnu/libc.so.6
The problem seems to be cause by a function in entry 11, but unfortunately I don't have DEBUG SYMBOLS for PlanAhead. The solution which I found (and doesn't involve running the software with root privileges) requires to create a symbolic link in ....Xilinx/14.6/ISE_DS/PlanAhead/tps/lnx64/jre/lib/amd64/server/  :
libjvm.so -> /usr/lib/jvm/java-7-openjdk-amd64/jre/lib/amd64/server/libjvm.so
What I noticed, it will work only with link to the OpenJDK. The same trick with java-7-oracle causes the known segmentation fault.
0
Thank you! This worked great for me on Ubunu 13.04 64bit.
Regular Visitor
0
Worked for me too. Thanks! (Mint 15, 64bit)
0
Thanks for that.  I can confirm this also works for Vivado on Ubuntu 13.04
I ran
mv /opt/Xilinx/Vivado/2013.2/tps/lnx64/jre/lib/amd64/server/libjvm.so /opt/Xilinx/Vivado/2013.2/tps/lnx64/jre/lib/amd64/server/libjvm.so.old
ln -s /usr/lib/jvm/java-7-openjdk-amd64/jre/lib/amd64/server/libjvm.so /opt/Xilinx/Vivado/2013.2/tps/lnx64/jre/lib/amd64/server/
0
This also worked for me for Vivado 2013.4 on Ubuntu 13.10:
mv /opt/Xilinx/Vivado/2013.4/tps/lnx64/jre/lib/amd64/server/libjvm.so /opt/Xilinx/Vivado/2013.4/tps/lnx64/jre/lib/amd64/server/libjvm.so.old
ln -s /usr/lib/jvm/java-7-openjdk-amd64/jre/lib/amd64/server/libjvm.so /opt/Xilinx/Vivado/2013.4/tps/lnx64/jre/lib/amd64/server/
0
I can confirm that this workaround also works on the new Ubuntu 14.04 (64bit)
0
Hello @lukasfischer ,
Thanks for the information. It will help others too.
Yash
0
Thank you.
confirmed to work under Fedora 19 x64
