Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
recorner
0
DDR3 multi-controller
I found that DDR3 surports up to 8 controllers, what is that use for? Is any demo that I can refer to?
Expert Contributor
eteam00
0
Re: DDR3 multi-controller
Do you mean that a DDR3 memory controller supports 8 access ports?
Which FPGA family are you using?
-- Bob Elkind
SIGNATURE:
Summary:
recorner
0
Thanks for your reply!
I learn that from MIG GUI, as the figure shows below. And I wander how to use it. Now I need ping-pong operation on DDR3 but I only get one DDR3 chip on my board. I don't know if it can help.
I am using Virtex-6 ML605, and MIG v3.61.
Expert Contributor
eteam00
0
[ Edited ]
I learn that from MIG GUI, as the figure shows below. And I wander how to use it. Now I need ping-pong operation on DDR3 but I only get one DDR3 chip on my board. I don't know if it can help.  I am using Virtex-6 ML605, and MIG v3.61.
If you have not already read UG406 and DS186, there is a great deal of helpful information available in these two documents.
You cannot connect a single DRAM device to more than one memory controller.
From DS186:
(DDR3)  Multiple controllers per FPGA supported through the Memory Interface Generator (MIG) tool.
(DDR2)  Multiple controllers per FPGA supported by running the MIG tool multiple times.
This should clarify the multi-controller message from the MIG GUI.
-- Bob Elkind
SIGNATURE:
Summary:
recorner
0
  I read UG406 and DS186 before. But I do not understand the description on DS186 because of my poor English. It will be greatful if you can explain it to me. Thank a lot!
Expert Contributor
eteam00
0
Please try to ask specific questions with sufficient details and context.  This will help developing useful answers.
-- Bob Elkind
SIGNATURE:
Summary:
recorner
0
Sorry didn't make myself clear, I mean the  description copy from DS186 below that I cannot understand:
"(DDR3)  Multiple controllers per FPGA supported through the Memory Interface Generator (MIG) tool."
Can you explain it in complete sentences?
And  in my opinion, I think it  means “a FPGA supportes Multiple controllers through MIG tool”, and usually a FPGA have only one DDR3 chip. Can I say that "a DDR3 on a FPGA supportes Multiple controllers"? It really makes me confused.
Thanks!
Expert Contributor
eteam00
0
Normally, if you want more than one memory controller in your FPGA design, you must run MIG once for each memory controller.  For Virtex-6 using DDR3 (but not DDR2), you can generate more than one memory controller in a single session of the MIG GUI.
This does not change the properties or capabilities of the Virtex-6 memory controllers generated by MIG.  This is just a reduction in the number of steps to build designs with multiple DDR3 memory controllers.
-- Bob Elkind
SIGNATURE:
Summary:
recorner
0
thanks! I've got it!
But I still have a question.
You mentioned that "you cannot connect a single DRAM device to more than one memory controller". Since Virtex-6 has only one DDR3 device, so I cannot use more than one memory controller to control the device at the same time, right? So,in what cases I should use or I must use multiple controllers ? It would be helpful if you can give me an example.
Thanks again!
Expert Contributor
rcingham
> So,in what cases I should use or I must use multiple controllers?
When you have more than 1 DDR3 device!
For instance a different board design.
"If it don't work in simulation, it won't work on the board."
