Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
Regular Visitor
tloesch
0
Accepted Solution
Simulation error HDLCompiler:661 in mcb_raw_wrapper.v
I included a MIG 3.3 IP in my project for SP605 development board using ISE11.5.  The design synthesizes fine but when I attempt to perform behavioral simulation I receive a HDLCompiler:661 errors in mcb_raw_wrapper.v like the ones listed below.  I get a total of 18 messages and the compile terminates with too many messages.  It appears that it is getting the error on every input port in mcb_raw_wrapper.v.
Line 264: Non-net port sysclk_2x cannot be of mode input
Line 265: Non-net port sysclk_2x_180 cannot be of mode input
Since the errors are happening within code generated by the IP I am not sure how to resolve the issue.  If I walk down the modules everything appears to be defined correctly
Any help you can provide would be appreciated.
Administrator
criley
0
Re: Simulation error HDLCompiler:661 in mcb_raw_wrapper.v
THe first thing I would check is that you have compiled the behavioral models for the correct version of ISE and that the MIG IP version is also matches with the same release.
Regular Visitor
tloesch
0
I must have modified one of the other MIG files by mistake when customizing the memc3_infrastructure.v file for the SP605 board.  I regenerated the core which resolved the problem.
Thanks for your help
