Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
noorulazim
0
Problem in generation of bit for single carrier qpsk transmitter
I designed Single Carrier QPSK Transmitter using Verilog. In simulation my whole desing work completly. but when i generate bit file for this design and download it to FPGA (ML605 Development ki) using chip scope pro then no signal will be displayed.
iguo
0
Re: Problem in generation of bit for single carrier qpsk transmitter
What kind of simulation did you run? With Behavior simulation only you might not get things running as expected. If DONE pin is high, this issue has no relationship with bit or configuration. You should check your design carefully, such as timing.
Expert Contributor
gszakacs
0
If ChipScope finds the core, then the FPGA is running from the .bit file, otherwise you will not
get a connection.
It's not clear what you mean by "no signal will be displayed" in ChipScope.  Can you get
ChipScope connected?  Can you set up a trigger?  If you click the "Trigger and stop"
button can you see signals in a window (whether or not they are toggling)?
-- Gabor
-- Gabor
noorulazim
0
ChipScope is connected but the signal displayed on chipscope is not QPSK modulated signal. it is simpl sine wave. my output signal should be qpsk modulated signal
noorulazim
0
