- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Required mcs data format informatio n for FPGA configurat ion
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
04-17-2012 08:23 AM
We are using ML605 board and writing .mcs file to external BPI flash using microblaze.So, queries are as follows:
1.need data format information to store .mcs onto BPI flash (means lower byte or higher byte first on flash)
2.How FPGA comes to know, end of configuration data file?during power on configuration
Please let me know
Thanks and Regards,
Prashant
Re: Required mcs data format informatio n for FPGA configurat ion
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
04-17-2012 08:29 AM
Prashant,
I suggest you download all the examples, build them, load them, and learn.
http://www.xilinx.com/products/boards-and-kits/EK-
Principal Engineer
Xilinx San Jose
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
04-17-2012 08:35 AM
thanks Austin Lesea,
I have downloaded all files but they are not solving our purpose so pls help me
Prashant
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
04-17-2012 08:45 AM
http://www.xilinx.com/support/documentation/user_g
Have you read this guide?
Principal Engineer
Xilinx San Jose
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
04-17-2012 08:47 AM
http://www.fpga-faq.com/archives/33100.html#33108
and there is a ton of information on the mcs file format out there....
Principal Engineer
Xilinx San Jose
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
04-20-2012 10:15 AM
Thanks Austin Lesea,
As .mcs frame format file consists of many fields like addr, device ID, data, checksum etc.
Is all these information is written onto BPI flash ,when it is programmed through JTAG? or only data is written because FPGA needs only data.
Pls let me know.
Prashant
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
04-20-2012 11:05 AM
Prashant,
The bitstream sytarts with the sync character string, and ends with the CRC check and startup commands.
Everything else before the sync is to document it for you.
Everything after the startup may be required for the startup (there may be a number of empty bytes at the end that need to be sent).
Principal Engineer
Xilinx San Jose
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
04-24-2012 09:56 AM
Thanks for your reply.
I need to understand the configuration data available for virtex-6 fpga.
The maximum configuration data available for virtex-6 fpga is 74Mbits and in ML605 board, FPGA connected to BPI flash which is 256Mbits of size.So, how fpga get configured, if configuration memory is more than 74Mbits.
Thanks and Regards,
Prashant
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
09-03-2012 10:35 PM
On this thread, I was hoping someone could help clear up a few unknowns for me.
1. The mcs file is in ASCII format. But you have to write the data in hex, right? (For clarity).
2. Which fields from the mcs file get written? At a guess, I would ignore everything except the data. Do I need to grab the payload from the Extended Linear Address field and concatenate it with the Hex address at the start of each Data record to generate my absolute address to write to the PROM at the beginning of each Page Program operation? Of which there would be one per data record?
3. Send all data including the sync sequence, so the FPGA can figure out what's going on as the serial stream arrives.
So in conclusion for the following file (snippet) :
:020000040000FA
:10000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF00
:10001000AA99556630A10007200031A10628314178
:100020003D00316109EE31C20400809330E100CF20
I would actually write the following into my PROM from my processor:
1. PROM instruction : BULK Erase = 0xC7
2. PROM instruction : Write Enable = 0x06
3. PROM instruction : Page Write = 0x02, 0x00 0x0000 0xFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
4. PROM instruction : Page Write = 0x02, 0x00 0x0010 0xAA99556630A10007200031A106283141
5. PROM instruction : Page Write = 0x02, 0x00 0x0020 0x3D00316109EE31C20400809330E100CF ...
Above the extended linear address field is 4 hex characters, which with the 16 bit hex address gives a total of 32 address bits. But the device is only 32M, and has 24 address bits. So I have to be careful to throw away unwanted address bits?
Hopefully the example above will allow someone who knows what they are looking at to correct my errors. Thanks in advance.
Al.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
09-04-2012 01:10 AM
I had to go through this whilst preparing the Flash memory programming reference designs for the Spartan-3 Starter kits. For example this PicoBlaze based design can read an MCS file and program a StartaFlash memory...
http://www.xilinx.com/products/boards/s3estarter/f
It looks like you are almost there yourself but here are my notes concerning MCS format (that I made at the time) which form the basis of the PicoBlaze code provided in the example indicated above.
If the address is less than 32-bits then you just use the lower bits (the upper bits should be zero anyway). The memory is only written with the ‘data’ and everything else defines where it should be written and provides a checksum that you can (should) use to verify that the memory is being programmed correctly (e.g. detect any communication errors). Each ASCII character represents a hexadecimal value and therefore 4-bits so remember to write the actual bits and not the ASCII character (I have truly lost count of how many people have made that mistake and asked me why it doesn’t work!).
INTEL MCS-86 file format notes.
Ken Chapman - 31st October 2005
Each line has a 9-character prefix with 4 fields
: Start Character
bb Byte count - number of data bytes on the line e.g. 10 is 16 bytes of data
aaaa Address
tt Record type
00 = Data record
01 = End of file record
04 = Extended Linear Address Record - provides offset to be added to the addresses.
This is followed by data bytes if relevant and a checksum
dddddd Data bytes
cc Checksum for the whole record formed by adding all bytes and 2's complementing the 8-bit result.
Here are some lines from a programming file for an XC3S500E
FIRST LINE
:020000040000FA
: 02 0000 04 00 00 FA
: Start Character
02 2 data bytes
0000 Address (unused in this record type)
04 Record type 04 (Extended Linear Address Record)
00 00 Offset address (zero in this case to start at address zero)
FA Checksum 02+00+00+04+00+00 = 06 Complement = FA
So after this line the full address is 0000aaaa.
MOST LINES (first 2 shown)
:10000000FFFFFFFF5599AA660C000180000000E089
:100010000C800680000000060C8004800000FCA715
: 10 0000 00 FF FF FF FF 55 99 AA 66 0C 00 01 80 00 00 00 E0 89
: 10 0010 00 0C 80 06 80 00 00 00 06 0C 80 04 80 00 00 FC A7 15
: Start Character
10 16 data bytes
0000
0010 Address increasing by 16 each line given that there are 16 bytes on a line
00 Data record
Byte data (16 bytes on each line)
89
15 Checksum
Sum of {10 00 00 00 FF FF FF FF 55 99 AA 66 0C 00 01 80 00 00 00 E0} = 777 Complement 77 = 89
Sum of {10 00 10 00 0C 80 06 80 00 00 00 06 0C 80 04 80 00 00 FC A7} = 3EB Complement EB = 15
CROSSING ADDRESS BOUNDARY LINE
Because the address field in each data record is only 16-bits, it means that an address can only
be up to FFFF. When the file size is larger than this, it needs to use the Extended Linear Address Record
to specify the next most significant bytes of the address.
:10FFF0000000000000000000000000000000000001
:020000040001F9
:1000000000000000000000000000000000000000F0
: 02 0000 04 00 01 F9
: Start Character
02 2 data bytes
00 01 Offset address to be added to address provided with data records
FA Checksum 02+00+00+04+00+01 = 07 Complement = F9
So after this line the full address is 0001aaaa
LAST LINE
:00000001FF
: 00 0000 01 FF
: Start Character
00 no data
01 End of file record
FF Checksum
Sum of {00 00 00 01} = 01 Complement 01 = FF
Principal Engineer, Xilinx UK
