Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
agnz
0
Synthesis results in incorrect netlist without KEEP_HIERARCHY on.
I have a very simple piece of Verilog code (see below) that I'm struggling to synthesise correctly using XST (ISE 13.4). Behavioural simulation is correct; however, post-translation simulation is not, neither is generated net-list. If I turn KEEP_HIERARCHY option on during synthesis, then the synthesised netlist is correct and post-translation simulation matches behavioral.
Am I doing something wrong with Verilog?
I have 2 modules. One module is a processing element (PE):
module PE(
	input L,
	input C,
	input R,
	input AL,
	input AC,
	input AR,
	input BL,
	input BC,
	input BR,
	output [0:0] D_o );
wire [3:0] sum;
// Compute how many neighbors are HIGH
assign sum = (L + R + AL + AC + AR + BL + BC + BR );
// If 3 are HIGH or 2 are HIGH and Center is HIGH output 1
assign D_o = (sum == 4'd3) || ((sum == 4'd2) && C);
endmodule
 And another module instantiates 4 of these PEs to process a stream of incoming data (4 bits at a time).
As I need 3x3 neighbourhood, I use a shift register to store 3 of the last data elements. The outputs of the register are connected to the inputs of the instantiated PEs:
module PEarray (
	input					CLK,
	input					CE,
	input		[3:0]		Darray_i,
	output 		Darray_o0,
	output 		Darray_o1,
	output 		Darray_o2,
	output 		Darray_o3
reg [3:0] left, centre, right; // store previous, current and future data
// Instantiate 4 processing elements
// Each processes a 3x3 neighbourhood: Above left (AC), Above Centre (AC), Above Right (AR)
//													Left,					Centre,				Right
//													Below Left(BL), Below Centre (BC), Below right (BR)
PE element0(
	 .L(left[0]),
	 .C(centre[0]),
	 .R(right[0]),
	 .AL(left[1]),
	 .AC(centre[1]),
	 .AR(right[1]),
	 .BL(0),					// Boundary condition: out of bounds = 0
	 .BC(0),
	 .BR(0),
    .D_o(Darray_o0) );
PE element1(
	 .L(left[1]),
	 .C(centre[1]),
	 .R(right[1]),
	 .AL(left[2]),
	 .AC(centre[2]),
	 .AR(right[2]),
	 .BL(left[0]),
	 .BC(centre[0]),
	 .BR(right[0]),
     .D_o(Darray_o1) );
PE element2(
	 .L(left[2]),
	 .C(centre[2]),
	 .R(right[2]),
	 .AL(left[3]),
	 .AC(centre[3]),
	 .AR(right[3]),
	 .BL(left[1]),
	 .BC(centre[1]),
	 .BR(right[1]),
    .D_o(Darray_o2) );
PE element3(
	 .L(left[3]),
	 .C(centre[3]),
	 .R(right[3]),
	 .AL(0),				// Boundary condition: out of bounds = 0
	 .AC(0),
	 .AR(0),
	 .BL(left[2]),
	 .BC(centre[2]),
	 .BR(right[2]),
    .D_o(Darray_o3) );
// One piece of data is fed every clock cycle
// Shift register to store left, centre and right required to process 3x3 neighbourhood
always @(posedge CLK)
begin
		right <= Darray_i;
		centre <= right;
		left <= centre;
end
endmodule
Thanks for help in advance.
Andrew
agnz
0
Re: Synthesis results in incorrect netlist without KEEP_HIERARCHY on.
I tried rewriting the PE module as a function:
function [3:0] PEf;
	input L,C,R,AL,AC,AR,BL,BC,BR;
begin : PEfunc
	reg [3:0] sum;
	sum = L + R + AL + AC + AR + BL + BC + BR;
	PEf = (sum == 4'd3) || ((sum == 4'd2) && C);
end
endfunction
 And using it in the following way:
assign Darray_o1 = PEf(
	 left[1],
	 centre[1],
	 right[1],
	 left[2],
	 centre[2],
	 right[2],
	 left[0],
	 centre[0],
	 right[0]);
 And now the synthesis is correct and so as post-translation simulation.
I really don't understand why it doesn't work as a module... Any hints?
