- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
WARNING:Xs t:647
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
04-30-2012 03:28 PM
Dear All,
Need some advice, I’m fairly new to this. I’m using an xc65108 chip to control some fairly simple things, programming in ISE 13.1 This is my dilemma:
In the entity top_level I’ve declare an in signal, further down in the “architecture Behavioral of top_level” I read the signal in an if loop. When I compile the code I get the following warning
“WARNING:Xst:647 - Input <BIT_1> is never used. This port will be preserved and left unconnected if it belongs to a top-level block or it belongs to a sub-block and the hierarchy of this sub-block is preserved.”
How do I get the code to understand that the signal is being used? What am I doing wrong? I do something similar with another signal declared and used in an if loop, but it does not give me any warnings there. Do I have to declare it in another form? Any input will be greatly appreciated because I’ve gone blind here and can’t see the problem. Thank you!
/Polly
Example
Entity :
BIT_1 : in STD_LOGIC;
STATUS_5V : in STD_LOGIC;
STATUS_1 : inout STD_LOGIC;
STATUS_2 : inout STD_LOGIC;
RADAR_OK : inout STD_LOGIC;
Behavioral:
--this code doesn’t generate warnings
process (STATUS_5V, R_OK)
begin
if (STATUS_5V = '1') then
R_OK <= '0';
else
R_OK <= '1';
end if;
end process;
--this gives me the WARNING: Xst:647
process (BIT_1, STATUS_1, STATUS_2)
begin
if (BIT_1 = '1') then
STATUS_1 <= '1';
else
STATUS_2 <= '1';
end if;
end process;
Re: WARNING:Xs t:647
[ Edited ]
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
04-30-2012 03:59 PM - edited 04-30-2012 04:02 PM
I can barely read VHDL, so I cannot comment on VHDL syntax issues. Here are some other suggestions to solve your immediate problem:
- Cast STATUS_1 and STATUS_2 as output rather than inout, until you have use for these signals as inout.
- Add logic which assigns '0' to STATUS_1 and STATUS_2. The synthesiser has no reason to infer that STATUS_1 and STATUS_2 can ever assume a '0' level, regardless of the state of input BIT_1. If BIT_1 does not affect any other variables or signals, then BIT_1 has no use in the synthesised logic. Hence the "never used" warning.
-- Bob Elkind
Summary:
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-01-2012 01:15 AM
Trying to use a language you do not understand.
Buy a book or do a course.
"If it don't work in simulation, it won't work on the board."
