Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
Regular Visitor
tayeb
0
how connect customized IP to PLB interface with fifo
I'm looking for someone who has already connected its own IP on the PLB bus with FIFO for he shares his experience with me, for me it's been a month since I tried to do unsuccessfully
I would like to have an exemple user_logic file where we connect our IP to the PLB interface with fifos
thanks
Regular Visitor
tayeb
0
Re: how connect customized IP to PLB interface with fifo
my user_logic.vhd:
architecture IMP of user_logic is
--USER signal declarations added here, as needed for user logic
-- Signals for user logic slave model s/w accessible register example
signal slv_reg0 : std_logic_vector(0 to C_SLV_DWIDTH-1);
signal slv_reg1 : std_logic_vector(0 to C_SLV_DWIDTH-1);
signal slv_reg2 : std_logic_vector(0 to C_SLV_DWIDTH-1);
signal slv_reg3 : std_logic_vector(0 to C_SLV_DWIDTH-1);
signal slv_reg4 : std_logic_vector(0 to C_SLV_DWIDTH-1);
signal slv_reg5 : std_logic_vector(0 to C_SLV_DWIDTH-1);
signal slv_reg_write_sel : std_logic_vector(0 to 5);
signal slv_reg_read_sel : std_logic_vector(0 to 5);
signal slv_ip2bus_data : std_logic_vector(0 to C_SLV_DWIDTH-1);
signal slv_read_ack : std_logic;
signal slv_write_ack : std_logic;
-- Signals for read/write fifo loopback example
type FIFO_CNTL_SM_TYPE is (IDLE, RD_REQ, WR_REQ);
signal fifo_cntl_ns : FIFO_CNTL_SM_TYPE;
signal fifo_cntl_cs : FIFO_CNTL_SM_TYPE;
signal fifo_rdreq_cmb : std_logic;
signal fifo_wrreq_cmb : std_logic;
--User signals
signal slv_reg0_sig : std_logic_vector(0 to C_SLV_DWIDTH-1);
signal slv_reg1_sig : std_logic_vector(0 to C_SLV_DWIDTH-1);
signal slv_reg2_sig : std_logic_vector(0 to C_SLV_DWIDTH-1);
signal slv_reg3_sig : std_logic_vector(0 to C_SLV_DWIDTH-1);
signal slv_reg4_sig : std_logic_vector(0 to C_SLV_DWIDTH-1);
--Declaration de ASEPA
component asepa_v3
port ( clk_bus : in std_logic;
data_in : in std_logic_vector (0 to 15);
dv : in std_logic;
inf_f1 : in std_logic_vector (0 to 15);
inf_f2 : in std_logic_vector (0 to 15);
inf_f3 : in std_logic_vector (0 to 15);
rcs : in std_logic_vector (0 to 15);
rst_sys : in std_logic;
rtm : in std_logic_vector (0 to 15);
seuil_div : in std_logic_vector (0 to 15);
sup_f1 : in std_logic_vector (0 to 15);
sup_f2 : in std_logic_vector (0 to 15);
sup_f3 : in std_logic_vector (0 to 15);
taille_ascan : in std_logic_vector (0 to 15);
alarme1 : out std_logic_vector (0 downto 0);
alarme2 : out std_logic_vector (0 downto 0);
alarme3 : out std_logic_vector (0 downto 0);
numero_ascan : out std_logic_vector (0 to 7);
read_ack : out std_logic_vector (0 downto 0));
end component;
begin
--USER logic implementation added here
instance: asepa_v3
port map (clk_bus =>Bus2IP_Clk,
data_in =>WFIFO2IP_Data(16 to 31),--fifo ---->IP
DV =>RFIFO2IP_WrAck ,
inf_f1 =>slv_reg0_sig(16 to 31),
inf_f2 =>slv_reg1_sig(16 to 31),
inf_f3 =>slv_reg2_sig(16 to 31),
RCS =>slv_reg4_sig(16 to 31),
rst_sys =>Bus2IP_Reset,
RTM =>slv_reg4_sig(0 to 15),
seuil_div =>slv_reg3_sig(0 to 15),
sup_f1 =>slv_reg0_sig(0 to 15),
sup_f2 =>slv_reg1_sig(0 to 15),
sup_f3 =>slv_reg2_sig(0 to 15),
taille_ascan =>slv_reg3_sig(16 to 31),
numero_ascan =>IP2RFIFO_Data(24 to 31),
alarme1 =>IP2RFIFO_Data(22 to 22),
alarme2 =>IP2RFIFO_Data(21 to 21),
alarme3 =>IP2RFIFO_Data(20 to 20),
read_ack =>IP2RFIFO_Data(23 to 23)
slv_reg0_sig<=slv_reg0;
slv_reg1_sig<=slv_reg1;
slv_reg2_sig<=slv_reg2;
slv_reg3_sig<=slv_reg3;
slv_reg4_sig<=slv_reg4;--rcs --rtm
-- Example code to read/write user logic slave model s/w accessible registers
-- Note:
-- The example code presented here is to show you one way of reading/writing
-- software accessible registers implemented in the user logic slave model.
-- Each bit of the Bus2IP_WrCE/Bus2IP_RdCE signals is configured to correspond
-- to one software accessible register by the top level template. For example,
-- if you have four 32 bit software accessible registers in the user logic,
-- you are basically operating on the following memory mapped registers:
-- Bus2IP_WrCE/Bus2IP_RdCE Memory Mapped Register
-- "1000" C_BASEADDR + 0x0
-- "0100" C_BASEADDR + 0x4
-- "0010" C_BASEADDR + 0x8
-- "0001" C_BASEADDR + 0xC
slv_reg_write_sel <= Bus2IP_WrCE(0 to 5);
slv_reg_read_sel <= Bus2IP_RdCE(0 to 5);
slv_write_ack <= Bus2IP_WrCE(0) or Bus2IP_WrCE(1) or Bus2IP_WrCE(2) or Bus2IP_WrCE(3) or Bus2IP_WrCE(4) or Bus2IP_WrCE(5);
slv_read_ack <= Bus2IP_RdCE(0) or Bus2IP_RdCE(1) or Bus2IP_RdCE(2) or Bus2IP_RdCE(3) or Bus2IP_RdCE(4) or Bus2IP_RdCE(5);
-- implement slave model software accessible register(s)
SLAVE_REG_WRITE_PROC : process( Bus2IP_Clk ) is
begin
if Bus2IP_Clk'event and Bus2IP_Clk = '1' then
if Bus2IP_Reset = '1' then
slv_reg0 <= (others => '0');
slv_reg1 <= (others => '0');
slv_reg2 <= (others => '0');
slv_reg3 <= (others => '0');
slv_reg4 <= (others => '0');
slv_reg5 <= (others => '0');
else
case slv_reg_write_sel is
when "100000" =>
for byte_index in 0 to (C_SLV_DWIDTH/8)-1 loop
if ( Bus2IP_BE(byte_index) = '1' ) then
slv_reg0(byte_index*8 to byte_index*8+7) <= Bus2IP_Data(byte_index*8 to byte_index*8+7);
end if;
end loop;
when "010000" =>
slv_reg1(byte_index*8 to byte_index*8+7) <= Bus2IP_Data(byte_index*8 to byte_index*8+7);
end if;
end loop;
when "001000" =>
slv_reg2(byte_index*8 to byte_index*8+7) <= Bus2IP_Data(byte_index*8 to byte_index*8+7);
end if;
end loop;
when "000100" =>
slv_reg3(byte_index*8 to byte_index*8+7) <= Bus2IP_Data(byte_index*8 to byte_index*8+7);
end if;
end loop;
when "000010" =>
slv_reg4(byte_index*8 to byte_index*8+7) <= Bus2IP_Data(byte_index*8 to byte_index*8+7);
end if;
end loop;
when "000001" =>
slv_reg5(byte_index*8 to byte_index*8+7) <= Bus2IP_Data(byte_index*8 to byte_index*8+7);
end if;
end loop;
when others => null;
end case;
end if;
end if;
end process SLAVE_REG_WRITE_PROC;
-- implement slave model software accessible register(s) read mux
SLAVE_REG_READ_PROC : process( slv_reg_read_sel, slv_reg0, slv_reg1, slv_reg2, slv_reg3, slv_reg4, slv_reg5 ) is
begin
case slv_reg_read_sel is
when "100000" => slv_ip2bus_data <= slv_reg0;
when "010000" => slv_ip2bus_data <= slv_reg1;
when "001000" => slv_ip2bus_data <= slv_reg2;
when "000100" => slv_ip2bus_data <= slv_reg3;
when "000010" => slv_ip2bus_data <= slv_reg4;
when "000001" => slv_ip2bus_data <= slv_reg5;
when others => slv_ip2bus_data <= (others => '0');
end case;
end process SLAVE_REG_READ_PROC;
-- Example code to transfer data between read/write fifo
-- Note:
-- The example code presented here is to show you one way of operating on
-- the read/write FIFOs provided for you. There's a set of IPIC ports
-- dedicated to the FIFO operations, beginning with RFIFO2IP_* or IP2RFIFO_*
-- or WFIFO2IP_* or IP2WFIFO_*. Some FIFO ports are only available when
-- certain FIFO services are present, s.t. vacancy calculation, etc.
-- Typically you will need to have a state machine to read data from the
-- write FIFO or write data to the read FIFO. This code snippet simply
-- transfer the data from the write FIFO to the read FIFO.
IP2RFIFO_WrMark <= '0';
IP2RFIFO_WrRelease <= '0';
IP2RFIFO_WrRestore <= '0';
IP2WFIFO_RdMark <= '0';
IP2WFIFO_RdRelease <= '0';
IP2WFIFO_RdRestore <= '0';
FIFO_CNTL_SM_COMB : process( WFIFO2IP_empty, WFIFO2IP_RdAck, RFIFO2IP_full, RFIFO2IP_WrAck, fifo_cntl_cs ) is
begin
-- set defaults
fifo_rdreq_cmb <= '0';
fifo_wrreq_cmb <= '0';
fifo_cntl_ns <= fifo_cntl_cs;
case fifo_cntl_cs is
when IDLE =>
-- data is available in the write fifo and there's space in the read fifo,
-- so we can start transfering the data from write fifo to read fifo
if ( WFIFO2IP_empty = '0' and RFIFO2IP_full = '0' ) then
fifo_rdreq_cmb <= '1';
fifo_cntl_ns <= RD_REQ;
end if;
when RD_REQ =>
-- data has been read from the write fifo,
-- so we can write it to the read fifo
if ( WFIFO2IP_RdAck = '1' ) then
fifo_wrreq_cmb <= '1';
fifo_cntl_ns <= WR_REQ;
end if;
when WR_REQ =>
-- data has been written to the read fifo,
-- so data transfer is done
if ( RFIFO2IP_WrAck = '1' ) then
fifo_cntl_ns <= IDLE;
end if;
when others =>
end case;
end process FIFO_CNTL_SM_COMB;
FIFO_CNTL_SM_SEQ : process( Bus2IP_Clk ) is
begin
if ( Bus2IP_Clk'event and Bus2IP_Clk = '1' ) then
if ( Bus2IP_Reset = '1' ) then
IP2WFIFO_RdReq <= '0';
IP2RFIFO_WrReq <= '0';
fifo_cntl_cs <= IDLE;
else
IP2WFIFO_RdReq <= fifo_rdreq_cmb;
IP2RFIFO_WrReq <= fifo_wrreq_cmb;
fifo_cntl_cs <= fifo_cntl_ns;
end if;
end if;
end process FIFO_CNTL_SM_SEQ;
--IP2RFIFO_Data <= WFIFO2IP_Data;
-- Example code to drive IP to Bus signals
IP2Bus_Data <= slv_ip2bus_data when slv_read_ack = '1' else
(others => '0');
IP2Bus_WrAck <= slv_write_ack;
IP2Bus_RdAck <= slv_read_ack;
IP2Bus_Error <= '0';
end IMP;
