Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
Regular Visitor
hse07013
0
AXI PCIe Bridge locks up
I use the AXI PCIe Bridge 1.03.a. I tried to send and receive data (4 kiB) concurrently from/to the slave bridge with two seperate DMAs. Due to the implemented ordering, the bridge locks up. Both DMAs stop working when transmitted about 1 kiB. The axi interconnect is in crossbar mode. Destination and source IP-Cores are non-blocking and well-tested.
My work around is to disable the ordering in the axi_pcie_mm_s_v1_03_a/hdl/vhdl/slave_bridge.vhd:
	 -- Ordering signals
-      slave_read_req_p        => slrdready,
-      slave_rd_req_go         => slrdsend,
-      slave_cmpl_rdy_p        => slcplready,
-      slave_cmpl_go           => slcplsend,
-      slv_write_idle          => sig_slv_write_idle,
-      master_wr_idle          => master_wr_idle,
	 -- Ordering signals
+      slave_read_req_p        => slrdready,
+      slave_rd_req_go         => '0', --slrdsend,
+      slave_cmpl_rdy_p        =>  slcplready,
+      slave_cmpl_go           => '0', --slcplsend,
+      slv_write_idle          => '1', --sig_slv_write_idle,
+      master_wr_idle          => '1', --master_wr_idle,
Here is the microblaze test code to reconstruct the calling order of the DMAs:
	XAxiPcie_BarAddr BarAddr;
	BarAddr.LowerAddr = 0x60000000;
	BarAddr.UpperAddr = 0x00000000;
	const u32 BytesToTransfer = 4096 * 4;
	u32 SrcAddr, DstAddr;
	 * Simple Mode from FPGA to Host
	SrcAddr = 0x30000000;
	DstAddr = 0xC0000000;
	PciePcieRegs[XAXIPCIE_AXIBAR2PCIBAR_0U_OFFSET / sizeof(u32)]
			= BarAddr.UpperAddr;
	PciePcieRegs[XAXIPCIE_AXIBAR2PCIBAR_0L_OFFSET / sizeof(u32)]
			= BarAddr.LowerAddr;
	PcieReadDmaRegs[XAXICDMA_CR_OFFSET / sizeof(u32)] = XAXICDMA_CR_RESET_MASK;
			= XAXICDMA_XR_IRQ_IOC_MASK | XAXICDMA_XR_IRQ_ERROR_MASK;
	PcieReadDmaRegs[XAXICDMA_SRCADDR_OFFSET / sizeof(u32)] = SrcAddr;
	PcieReadDmaRegs[XAXICDMA_DSTADDR_OFFSET / sizeof(u32)] = DstAddr;
	PcieReadDmaRegs[XAXICDMA_BTT_OFFSET / sizeof(u32)] = BytesToTransfer;
	 * Simple Mode from Host to FPGA
	SrcAddr = 0xE0000000;
	DstAddr = 0x40000000;
	PciePcieRegs[XAXIPCIE_AXIBAR2PCIBAR_2U_OFFSET / sizeof(u32)]
	PciePcieRegs[XAXIPCIE_AXIBAR2PCIBAR_2L_OFFSET / sizeof(u32)]
	PcieWriteDmaRegs[XAXICDMA_CR_OFFSET / sizeof(u32)] = XAXICDMA_CR_RESET_MASK;
	PcieWriteDmaRegs[XAXICDMA_SRCADDR_OFFSET / sizeof(u32)] = SrcAddr;
	PcieWriteDmaRegs[XAXICDMA_DSTADDR_OFFSET / sizeof(u32)] = DstAddr;
	PcieWriteDmaRegs[XAXICDMA_BTT_OFFSET / sizeof(u32)] = BytesToTransfer;
Hopefully you can reproduce the issue and fix it in the next version.
Best regards,
Bernhard
It's always good practice giving feedback, when description/solution/recommendation have been helpful!
