Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
bharathiy@vrindatech.com
0
PCI express
hi.
i m new to PCI express.
in one of our design we are using SPARTAN-6 based board with PCI-express interface.
can anyone help me by telling what are the main hurdles to pass the design in software and hardware wise.
thanks,
Bharathi
jayer
0
Re: PCI express
I think you should focus on getting the example design provided to come up and run on the SP606 board. This would familiarize you with different aspects of the design process using the core.
John
0
Re: PCI express
hi,
thanks for your suggestion.
ya we are referring SP605 spec. main hurdle in our case is, FPGA taking 172ms to boot from SPIx4.this configuration timing how can i reduce???
jayer
0
Re: PCI express
Doesnt th eSP605 also have a x16 BPI configuration option. I think that would be faster. Although I have not looked at this board lately so it might be best to check the Board UG to be sure.
If you are plugging into a standard system with an ATX power supply 172 ms config time should be OK because you have the 100 ms from power stable plus an ATX supply provides a 100 ms buffer before power stable is asserted.
John
bg2bkk
0
Re: PCI express
I am not new to PCIE.I have a design for ML555 but not for ML506, I leave my college and now I just have a board ML506.So Where can I get a Example for PCIE on ML506.Thank you
Expert Contributor
sushantm
0
Re: PCI express
If you have tried google then you must found ML506 PCIe x1 Endpoint Design.
However for ML506 here is the link for its reference designs.
http://www.xilinx.com/products/boards/ml506/reference_designs.htm
http://www.xilinx.com/products/boards/ml506/ml506_12.1/pcie.htm
--Sushant Mahajan
Signature:
1.Have you ever tried typing your question into Google? If not you should before posting.
2.Read the datasheet and user guide. Have you read the user guide in detail ? Can you find the user guide?
3. Search the forums for similar topics.
4.I have neither found any similar thread in existing forum nor web-search is helpful to me.What should I do ?
Post your issue in detail comprehensive format on the relevant
forum.
5. Do not post the same question on multiple forums,please search and post it on relevant forum.
6. Do not raise a new topic or question on someone else's thread, start a new thread!
7. Students/Newbies: Copying code is not the same as learning to design.
8. "It does not work" is not a question which can be answered. Provide much details (with webaddress, datasheet links,etc..).
and make sure to be specific!
9. You are not charged extra fees for comments in your code,It will help others to understand well.
10.If someone answers your question, mark the post with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left).
