- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Spartan 6 PCIe help
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-08-2012 11:58 AM
Hello members,
I start to get my hands on Xilinx (still from Altera). I have a Spartan 6 Connectivity Kit with PCIe. I get it works fines with USB, UART and runs program to read/write memory. But when I install PCIe into my computer, I followed the instruction steps, but no luck to get the board to run. I'm really want to get the advantage of PCIe with dma transfter...
Is there sgdma in Xilinx???? On Altera, I'm very familiar with DMA and SGDMA ...
Sean
Re: Spartan 6 PCIe help
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-23-2012 06:47 AM
We do have a SGDMA, but you'll have to use the PCI Express Memory Mapped brigde with the Central DMA IP within EDK. Just because it's using EDK, doesn't mean that you need MicroBlaze. You can simply have the following IP in EDK and it should be able to work:
PCIe Memory Mapped Bridge http://www.xilinx.com/support/documentation/ipembe
Central DMA http://www.xilinx.com/support/documentation/ipembe
AXI interconnect
DDR3
and maybe some BRAM
It's simply enough to configure the Cental DMA core to be in SG mode.
Hope this helps...
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-23-2012 07:33 AM
i had not tried with SGDMA till now....
Probably if you have SP605 you can try with this App.
There is ready reference design available from Xilinx to test the PCIe Demo Performance results with DMA.
Signature:
1.Have you ever tried typing your question into Google? If not you should before posting.
2.Read the datasheet and user guide. Have you read the user guide in detail ? Can you find the user guide?
3. Search the forums for similar topics.
4.I have neither found any similar thread in existing forum nor web-search is helpful to me.What should I do ?
Post your issue in detail comprehensive format on the relevant
forum.
5. Do not post the same question on multiple forums,please search and post it on relevant forum.
6. Do not raise a new topic or question on someone else's thread, start a new thread!
7. Students/Newbies: Copying code is not the same as learning to design.
8. "It does not work" is not a question which can be answered. Provide much details (with webaddress, datasheet links,etc..).
and make sure to be specific!
9. You are not charged extra fees for comments in your code,It will help others to understand well.
10.If someone answers your question, mark the post with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left).
