- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
I have a problem with PicoBlaze simulation
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
04-22-2011 04:17 AM
Hi all:
I am trying to control a dc servo Motor using a SpartanII-xcs100.I use PicoBlaze to implement this task. I know that this version is obsolete, but this is the available FPGA board at the moment.
The problem that I have is , when I am trying to simulate the design with Modelsim 6.5 I get the following error messages.
“# -- Compiling architecture low_level_definition of pico_cnt
# ** Error: PICO_CNT.VHD(89): near "port": syntax error
# ** Error: PICO_CNT.VHD(49): No statement with label "ram_256_x_16" was found.
# ** Error: PICO_CNT.VHD(97): VHDL Compiler exiting
# ** Error: C:/modeltech_6.5/win32/vcom failed.
# Error in macro ./pico_cnt.ldo line 4
# C:/modeltech_6.5/win32/vcom failed.
# while executing
# "vcom -93 -explicit PICO_CNT.VHD"”.
The module “PICO_CNT.VHD” is the PicoBlaze’s code memory. I compared the generated VHDL file that KCPSM3’s compiler generates for the KCPSM3’s code memory and that the KCPSM’s compiler generates I found that both are identical from the syntax point of view, of course they are different in the code memory size.
The question is:
How can I sort out this problem to get rid of these irritating error messages that I get from ModelSim 6.5.?
Kind regards;
Re: I have a problem with PicoBlaze simulation
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
04-22-2011 05:41 AM
I would suggest going to the referenced line in the file and see if you can find
the syntax error. Since this was an early version of the PicoBlaze, it's possible it
uses something that is not compatible with newer VHDL. I believe ModelSim should
have a switch to set the version of VHDL used for compiling. It may be as simple as
a port or signal name that uses a reserved keyword in the newer VHDL syntax.
As a fall-back you could always download a much earler version of ModelSim,
I think 5.7 would be about the right vintage for the earliest (Virtex 1 and Spartan 2)
version of PicoBlaze. But I'd first look to see if there is something obvious in the
code, or if you can set the compile options to use an older syntax.
-- Gabor
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
04-22-2011 10:57 AM
First of all thanks for the reply;
Really, I switched between the different VHDL versions in the complier options in the model sim but I still got the same error messages. I used modelsim 5.7f, however I got another errors,
# ** Error: (vcom-42) Unsupported ModelSim library format for "work". (Format: 3)
# ** Fatal: Unexpected signal: 11.
# ** Error: PICO_CNT.VHD(23): VHDL Compiler exiting
# ERROR: C:/Modeltech_5.7f/win32/vcom failed.
Could you tell me please how I can turn around these errors ?
Regards;
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
04-22-2011 11:27 AM
This probably means that ModelSim found the work library created by the newer version
and doesn't understand it. You need to delete the work library and re-build it with 5.7f
If you haven't already done so, you may also have to re-compile the Xilinx libraries
using compxlib.
-- Gabor
[ Edited ]- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
04-26-2011 08:08 AM - edited 04-26-2011 08:11 AM
We are taking about code that was written in 2002 so certainly you would have to be sure that whatever tools you are trying to use today have access to the library components used at that time. I just looked for the BRAM component in ISE v12.4 and it is in there but you may need to check what your simulator library is too.
Now thinking back there was a small syntax error in the ‘ROM_form.vhd’ template. Take a look in your template a see if you see this line in the ‘generic map’….
INIT_0F => X"{INIT_0F}",
If yes, then change it to the following (comma becomes a closing bracket)….
INIT_0F => X"{INIT_0F}")
Run the assembler again so that the modification gets into your program memory definition file.
Principal Engineer, Xilinx UK
