Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
marthamanohar
0
KCPSM3 assembler not working
Hi sir, am using Spartan, I have wrote assembly code in .psm extension and it is error free.
But my kcpsm3 assembler showing the file .psm not in working directory although i put in the working directory
am using windows Xp. the assembler not working if i drag the .psm file into assembler dos prompt it generating log file and fmt files. could you please help me. i also downloaded kcpsm6 that is working properly and generating filename.vhd file.
 can i use this file for spartan3 ,
Expert Contributor
eilert
Re: KCPSM3 assembler not working
the KCPSM6 can not be used for KCPSM3 designs.
The resulting binary code is different.
What do you mean by "dragging the psm file to dos prompt"?
does there actually something useful happen?
When your command line interface is open, and you are in the right directory you normally
have to type sth. like:
kcpsm3 myfile.psm
Then you are able to see the resulting messages on the screen.
Also, you should read the log file.
If no .vhd file was created, maybe the reason for that can be found in the log.
Have a nice synthesis
  Eilert
