- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Routing KCPSM6 output to command-li ne?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
04-06-2012 12:34 PM
We use Linux systems pretty much exclusively, so running kcpsm6.exe is a bit of a pain. With a simple WINE installation, it works just fine. However, the main issue is that every time there's an error, you can only see it on the graphical window that pops up. I do a lot of work remotely, SSHing into the my computer from elsewhere, so obviously I cannot see that window.
Are there any command-line switches that will force kcpsm6 to either send compile errors to the command-line or force writing to a log, even when the build does not succeed? I haven't found any relevant info online.
Re: Routing KCPSM6 output to command-li ne?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
04-07-2012 03:52 AM
I recently made the KCPSM6 Assembler write a session log file and expect to release that version fairly soon. If you want to help test it in your environment then please drop me a direct email and I'll send it to you.
Principal Engineer, Xilinx UK
