Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
elharrach
0
Re: spartan3
and when i use a 5 pin jtag that exist in this card ,i will buy an simple jtag ,because the jtag is standard ,or for each card there must a special jtag ?
Expert Contributor
bassman59
0
Re: spartan3
Duh! All you need is a USB cable!
-a
Yes, I do this for a living.
barriet
0
Re: spartan3
And the USB cable in question is included in the S3ESK kit.
Using your existing resources (S3ESK documentation and those provided in your other threads) - this should be clear.
Should you elect to not use the on-board JTAG programming cable and supply another one to connect to the JTAG chain (why, I'm not sure), you'll want a Xilinx programming cable adaptor. While JTAG is standardized (e.g. IEEE1149.1) the software interface to the cables is not. Chipscope/XMD/iMPACT/etc. are expecting a Xilinx cable like the PC4 or Platform USB.
bt
elharrach
0
Re: spartan3
then if you can RECONFIGURE rom with a simple cable usb , why is there jtags  pin ,and all this complexity ,because there is a pin in the card that can be no used!!!,
THANK YOU VERY MUCH
barriet
0
Re: spartan3
The alternate JTAG header (J28) is provided for applications that can't use the embedded Platform USB, e.g.
-your computer doesn't have a USB port (and you need to use a Parallel-IV cable)
-you are using a version of ISE prior to introduction of support for the Platform USB
It is also likely a tradition to provide JTAG access via a header and some users would expect it.
The SPI header (J12) is provided to program the SPI Flash - which is a different interface and protocol.
From the S3EK User Guide (ug230.pdf):
The starter kit board also includes an on-board USB-based JTAG programming interface.
The on-chip circuitry simplifies the device programming experience. In typical
applications, the JTAG programming hardware resides off-board or in a separate
programming module, such as the Xilinx Platform USB cable.
Download FPGA designs directly to the Spartan-3E FPGA via JTAG, using the onboard
USB interface. The on-board USB-JTAG logic also provides in-system
programming for the on-board Platform Flash PROM and the Xilinx XC2C64A CPLD.
SPI serial Flash and StrataFlash programming are performed separately.
Embedding this circuitry saves the average user from having to purchase a cable that is roughly the same cost as the board itself.
Since customers expect an evaluation board with a lot of configuration flexibility, our boards likely have more configuration circuitry than the average FPGA board.
bt
elharrach
0
Re: spartan3
can i store program of keyboard with jtag ?
on the occasion ,is there a program of keyboard ps/2?
THANK YOU
elharrach
0
Re: spartan3
can i store program of keyboard with jtag ? on the occasion ,is there a program of keyboard ps/2? THANK YOU
praveenk
0
Re: spartan3
hi,i am trying to use the picoblaze implemented frequency counter using KCPSM3...............its the same program given on xilinx frequence counter which is for Spartan 3E XC500E . but i am having a spartan 3 kit and i am trying to program it on spartan 3 ,i am getting some errors which i am unable to solve ...can some one help me with the errors............ the errors are:- Pack:679 - Unable to obey design constraints (LOC=SLICE_X8Y29) which require the combination of the following symbols into a single SLICEM component: MUXCY symbol "processor/sel_shadow_muxcy" (Output Signal = processor/sel_carry) MUXCY symbol "processor/zero_cymux" (Output Signal = processor/zero_carry) The carry muxes are not connected in the required manner. Please correct the design constraints accordingly.
