- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Spartan 6 SPI Flash post-confi guration use
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
11-23-2011 07:28 AM
Having looked through XAPP951, XAPP1020 and UG380, I'm not sure that I fully understand that an SPI Flash (probably going to be a Spansion S25FL032P) can be used as User Storage post-configuration WITHOUT having to instantiate a STARTUP primitive (like in Virtex-5) or provide secondary lines to the Flash device (probably needing some tristating arrangement and various pullups).
So, my question is, can I connect the SPI Flash to the FPGA as suggested by UG380 for master serial configuration and then, in the .ucf, connect the outputs from an XPS SPI IP to the requisite pins (MOSI, DIN, CSO_B, CCLK as user i/o) to drive the Flash after configuration?
Diagram attached for clarification.
Thanks in advance.
Howard
"That which we must learn to do, we learn by doing." - Aristotle
Solved! Go to Solution.
Re: Spartan 6 SPI Flash post-confi guration use
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
11-23-2011 09:21 AM
I have this working, so I can say this absolutely works with Spartan 6, there is no need for additional primitives.
Bill
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
11-25-2011 03:07 AM
Good news. Thanks Bill.
Howard
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
12-12-2012 02:01 AM
By assuming the SPI FLASH can be used as User Storage post-configuration, I guess I can also drive the Flash after configuration to OVERWRITE the current configuration ?
Actually, I would like to have "Post-Configuration Access" to the SPI FLASH (like described in XAPP1020 for Virtex-5 : http://www.xilinx.com/support/documentation/applic
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
12-13-2012 02:22 PM
You should probably have started a new thread, referencing this one, as this is marked as solved. However, a quick answer - I have used both multiboot and post-config access to the flash to write new config data to different areas of the memory for remote updating. It works.
Start a new thread if you something specific to ask.
Howard
