Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
zhgwork
0
programming the spi flash failed
Hi all, I'm trying to load the .mcs file into a SPI FLASH PROMs(M25P40) using the Xilinx Platform Cable USB II. The problem is, I was able to load the .bit file into FPGA but I can't load .mcs file into SPI FLASH. there is always error message:
INFO:iMPACT - Current time: ????? ??? 18 15PROGRESS_START - Starting Operation.
Maximum TCK operating frequency for this device chain: 25000000.
Validating chain...
Boundary-scan chain validated successfully.
'1': SPI access core not detected. SPI access core will be downloaded to the device to enable operations.
INFO:iMPACT - Downloading core file F:/Xilinx/12.2/ISE_DS/ISE/spartan6/data/xc6slx16_spi.cor.
'1': Downloading core...
 LCK_cycle = NoWait.
LCK cycle: NoWait
done.
'1': Reading status register contents...
INFO:iMPACT:2219 - Status register values:
INFO:iMPACT - 0011 1100 1110 1100
INFO:iMPACT:2492 - '1': Completed downloading core to device.
'1': IDCODE is '00' (in hex).
'1': ID Check failed.
INFO:iMPACT:2488 - The operation did not complete successfully.
INFO:iMPACT - SPI Device not found.
INFO:iMPACT - '1': Flash was not programmed successfully.
PROGRESS_END - End Operation.
Elapsed time =      3 sec.
:11:56 2010
:10:00 2010
:08:59 2010
zhgwork
0
Re: programming the spi flash failed
Could you please help me to solve this? Thanks.
borisq
0
hi zhgwork,
the issue is IDCODE check failure.
The IDCODE iMPACT reads from SPI is 00, which means the MISO is always low.
you can probe the pin with an oscilloscope and check to see if the MISO toggles when you perform programming operations.
zhgwork
0
Yes. The MISO signal is always low. But the MOSI is always HIGH.
zhgwork
0
Addationally, the CSO and CCLK signals is corrected.
zhgwork
0
error message:
INFO:iMPACT - Current time: ������ ʮ�� 2// *** BATCH CMD : Program -p 1 -spi
Validating chain...
 LCK_cycle = NoWait.
LCK cycle: NoWait
done.
'1': Programming device...
 LCK_cycle = NoWait.
LCK cycle: NoWait
done.
[0] CRC ERROR                                                              :         0
[1] IDCODE ERROR                                                           :         0
[2] DCM LOCK STATUS                                                        :         1
[3] GTS_CFG_B STATUS                                                       :         1
[4] GWE STATUS                                                             :         1
[5] GHIGH STATUS                                                           :         1
[6] DECRYPTION ERROR                                                       :         0
[7] DECRYPTOR ENABLE                                                       :         0
[8] HSWAPEN PIN                                                            :         1
[9] MODE PIN M[0]                                                          :         1
[10] MODE PIN M[1]                                                         :         1
[11] RESERVED                                                              :         0
[12] INIT_B PIN                                                            :         1
[13] DONE PIN                                                              :         1
[14] SUSPEND STATUS                                                        :         0
[15] FALLBACK STATUS                                                       :         0
INFO:iMPACT:579 - '1': Completed downloading bit file to device.
INFO:iMPACT - '1': Programming not completed successfully.
Elapsed time =      2 sec.
1 14:53:19 2010
1 14:45:50 2010
1 14:38:58 2010
1 14:38:54 2010
1 14:34:28 2010
1 14:31:38 2010
1 14:27:13 2010
borisq
0
I review your schematic.
I see you connect CMPMOSI to the SPI.
you should use MOSI, not CMPMOSI.
Boris
p0o9i8
0
had the same problem , turned out that the wrong CS* was connected. (CSI_B_0 instead of FCS_B)
