- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
xcf128x :Failed at address, 0.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
10-08-2011 01:42 AM
I use XCF128X on my board to support virtex6 FPGA XC6VLX240T, but I cannot program this flash probably.
I read ug438 and check my schematic to the correct pin connections in the data sheet. I use slave selectmap mode .
the m[2:0] = 110 and the frequency of cclk is 40MHz
I use iMPACT 11.5 and the log is attached as following:
Boundary-scan chain validated successfully.
1: Device Temperature: Current Reading: 36.10 C, Min. Reading: 30.20 C, Max. Reading: 36.59 C
1: VCCINT Supply: Current Reading: 0.964 V, Min. Reading: 0.961 V, Max. Reading: 0.967 V
1: VCCAUX Supply: Current Reading: 2.528 V, Min. Reading: 2.525 V, Max. Reading: 2.534 V
Setting Flash Control Pins ...
Setting Configuration Register ...
Populating BPI common flash interface ...
Common Flash Interface Information Query completed successfully.
INFO:iMPACT - Common Flash Interface Information from Device:
INFO:iMPACT - Verification string: 51 52 59
INFO:iMPACT - Manufacturer ID: 49
INFO:iMPACT - Vendor ID: 01
INFO:iMPACT - Device Code: 18
Using x16 mode ...
'1': Reading device contents...
'1': Verification Terminated.
PROGRESS_END - End Operation.
Please help me to solve this problem
Re: xcf128x :Failed at address, 0.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
10-20-2011 01:40 AM
Run standalone Erase, Program and Verify, what do you get?
If you only fail in the Verify process, try to readback the content of 128xl and see if the image you programmed into it is correct.
