Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
Super Contributor
eng.amr2009
0
Accepted Solution
Change Simulation Resolution
Hi everybody,
I'm using ISIM through project navigator ISE13.3
How can i modify the simulator resolution ? I see that it can be modified in command line switches of the FUSE command. But within project navigator how can i do it ?
Thanks in advance
Expert Contributor
gszakacs
0
Re: Change Simulation Resolution
If you open the Isim properties dialog box, there should be a line called "Other Compiler Options"
that allows you to enter the FUSE command line options directly.
-- Gabor
-- Gabor
