- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
ERROR:Comp xlib:368 - Compxlib does not support mti_se version 6.3b or prior releases.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
12-17-2010 11:41 PM
I have been using ISE 12.3 (Linux 64) and simulation using isim. All working fine. But I have just installed Modelsim SE 10.0 and have been having difficutly getting ISE to use modelsim. I modified the Design Properties to select the Modelsim-SE Verilog simulator and ISE seems to have picked up the correct path to my modelsim installation directory. However, when I tried to simulate my test bench (from ISE), the ISE Project Navigator produced a warning window: "WARNING: Failed to get the pre-compiled simulation library information..." After some reading of the manual I concluded that I need to precompile the simulation libraries using the compxlib command. Doing so, I get this error:
ERROR:Compxlib:368 - Compxlib does not support mti_se version 6.3b or prior releases. Parsing through the path setting on your system we have identified that you are using mti_se '2010.12'.
Please contact Mentor Graphics to upgrade to a supported simulator version. If the path setting is incorrect, please ensure that you are pointing to the latest version and re-invoke compxlib.
The list of supported simulator versions are listed in the Simulation Chapter of the Synthesis and Simulation Design Guide on http://www.xilinx.com.
Simulator 'mti_se' is ignored.
I have the latest version of Modelsim. Is this a bug? If not, can anyone hint as to where I go from here?
Cheers,
Nathan
Solved! Go to Solution.
Re: ERROR:Comp xlib:368 - Compxlib does not support mti_se version 6.3b or prior releases.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
12-18-2010 06:27 AM
looks like you need to downgrade to modelsim 6.x, had same problem and downgrade worked :)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
12-19-2010 06:12 PM
What command options did you use when running compxlib?
-s and -p could be used to specify simulator and its executable path.
[ Edited ]
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
12-20-2010 09:08 AM - edited 12-20-2010 09:09 AM
I have the same problem. Here's the options I used:
compxlib -s mti_pe -p "C:\Program Files\Modelsim_PE_10.0\win32pe" -l all -arch spartan6 -arch virtex5 -arch virtex6 -lib all -w
ERROR:Compxlib:368 - Compxlib does not support mti_pe version 6.3b or prior releases. Parsing through the path setting on your system we have identified that you are using mti_pe '2010.12'.
Simulator 'mti_pe' is ignored.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
12-20-2010 12:38 PM
It looks like ModelSim 10.0 is too new for Compxlib to recognize as a successor to 6.3b. Your best bet is to downgrade one version down and install 6.6d instead. The archive is located at http://model.com/content/modelsim-pe-simulation-an
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
12-20-2010 12:42 PM
All,
Please see Xilinx Answer 38609: http://www.xilinx.com/support/answers/38609.htm
This is a known issue and will be addressed in ISE Design Suite 13.1, due out Spring.
For 12.3 and 12.4, use the latest modelSim 6.6 update.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
12-21-2010 08:57 AM
Please open a case with technical support if you cannot wait. A tactical patch could be made avaialble if needed.
Duth
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
12-22-2010 01:50 AM
Thanks for your help everyone.
I chose to revert back to modelsim 6.6d. This works fine and will do until the new version of ISE is available.
Cheers,
Nathan
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
03-29-2011 01:11 PM
Was a patch ever made to fix this issue for ISE 12.3?
I have just upgraded to Modelsim 10.0a and get this error with 12.3.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
03-30-2011 08:17 AM
There should have been one for 12.3 or 12.4, please open a case to get access to it.
Is there a reason why you cant upgrade to 13.1 of ISE? The issue does not exist in 13.1..
Duth
