- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
ISE simulation error
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
04-29-2012 09:37 PM
I have a problem when I Generate Expected Simulation Results process For the test bench waveform
This is the error that appears every time,
Running Fuse ...
ERROR:Simulator:418 - Compilation failed: vhpcomp: The system cannot find the file specified..
Can anyone suggest how can I solve this problem??
Re: ISE simulation error
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-02-2012 08:16 PM
Can you elaborate your problem with more details? What ISE version?
What operation did you perform in GUI?
Any more information in fuse.log?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-14-2012 01:08 AM
Hi thanka you for replying.
I am using ISE 8.1 version.
I have generated code for a communication transmitter in xilinx. I want to test
the module by simulation. So under behavioral simulation i created a testbench
waveform for the same. After assignin all the inputs I tried to generate the waveform
by I got the above error.
There is no other information available in fuse.log
Kindly help.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-14-2012 09:34 PM
Well, 8.1 is a bit old and the waveform testbench is deprecated in the current ISE.
The .tbw will be first converted to an HDL testbench .tfw and used in fuse.
Select the .tbw and double click "View Generated Testbench as HDL". Normally it outputs a .tfw.
You can try renaming it to .v or .vhd and replacing the waveform with this testbench.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-15-2012 09:13 PM
Thanks for your reply.
As you have mentioned the .tbw file outputs a .tfw file when we select generate waveform. But I couldnt find .tfw file in my directory. There was one .vhw file. I think you mean the same file. I tried converting the file to .vhd file and use it to simulate the waveform. But still the same error persists. should I try upgrading my simulator to ISE 10.1.
Kindly reply
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-15-2012 10:38 PM
prink wrote:
Kindly reply
Upgrade the tools to the latest version (13.4, I think).
Forget about drawing waveforms and create a proper VHDL test bench.
Yes, I do this for a living.
