Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
rdelario
0
ModelSim ERROR: unisim.vcomponents
I have these lines in my code:
library UNISIM;
use UNISIM.Vcomponents.ALL
and when I tried to vcom the vhd file that has that code in modelsim, I got this error:
# ** Error: (vcom-11) Could not find unisim.vcomponents.
# ** Error: ./../rtl/rtl_reorg/psa_d/psa_core/clock_gen/dll_div_s3e.vhd(27): (vcom-1195) Cannot find expanded name: 'unisim.vcomponents'.
# ** Error: ./../rtl/rtl_reorg/psa_d/psa_core/clock_gen/dll_div_s3e.vhd(27): Unknown record element "vcomponents".
# ** Error: ./../rtl/rtl_reorg/psa_d/psa_core/clock_gen/dll_div_s3e.vhd(30): VHDL Compiler exiting
any idea how to resolve this??
many thanks
rdelario
0
Re: ModelSim ERROR: unisim.vcomponents
nevermind this...
I found it out... just had to copy all unisim vhd files to unisim directory of modelsim, and compile them separately...
krzysiu-m
0
hi
I have found the same problem as you discover. I read your solution but i dont' understand it. can you describe useing more detail exactly what files, from where and what is destination files to copy this things.
best regards
rdelario
0
you can find unisim files in your Xilinx installation directory, in my case:
C:\Xilinx\webpack10.1\ISE\vhdl\src\unisims
what I did was, I copied those necessary files to my simulation directory.  then, your modelsim .do file will have to compile them:
vcom -93 -explicit -reportprogress 300 -work unisim  {./XilinxCoreLib/unisim_vcomp.vhd}
  vcom -93 -explicit -reportprogress 300 -work unisim  {./XilinxCoreLib/unisim_VPKG.vhd}
   vcom -93 -explicit -reportprogress 300 -work unisim  {./XilinxCoreLib/bufg.vhd}
   vcom -93 -explicit -reportprogress 300 -work unisim  {./XilinxCoreLib/ibufg.vhd}
   vcom -93 -explicit -reportprogress 300 -work unisim  {./XilinxCoreLib/dcm_sp.vhd}
give that a try...
cheers
gortipavan
0
Hello all...
 I am having the same problem as below.can anyone tell me how to get rid of this?
gortipavan
0
hello all...
I am having te same problem as below.Can anyone tell me how to get rid of it?
mcgett
0
Copying the simulation library files to your working directory isn't the best way.  Instead you should run the compxlib program to compile the libraries correctly for your simulator.  More information can be found here:
http://www.xilinx.com/itp/xilinx10/isehelp/pp_p_process_compile_hdl_simulation_libraries.htm
Have you tried typing your question into Google? If not you should before posting.
gortipavan
0
Than you very much...that helped!
rameshr1987
0
library UNISIM;
# ** Error: des.vhd(20): Library unisim not found.
# ** Error: des.vhd(21): (vcom-1136) Unknown identifier "unisim".
# ** Error: des.vhd(23): VHDL Compiler exiting
# ** Error: d:/win32xoem/vcom failed.
how to solve this errors?
please reply me
hakim_15
0
thank you so much
