- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Best PLL performanc e at bottom, middle, or top of VCO range?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-23-2012 12:57 PM
I'm using a Spartan-6 PLL to remove clock jitter, and I have a lot of flexibility in what I set the VCO frequency to (by manipulating the M+D values as well as the parameters on the DCM feeding the PLL).
UG382, page 102, says "the goal is to make D and M values as small as possible while keeping f_VCO as high as possible" which seems to imply that the PLL performs best when the VCO frequency is as high as possible yet still within the datasheet parameters -- around 1Ghz. Is this true? I'm not an analog guy, but all things being equal I'd suspect that circuits don't generally perform best at the outer limits of their specifications.
If it matters, I am using the PLL only for jitter filtering.
Solved! Go to Solution.
Re: Best PLL performanc e at bottom, middle, or top of VCO range?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
07-23-2012 03:41 AM
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
07-23-2012 04:09 PM
Thanks jheslip, that was really helpful!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
09-06-2012 04:39 AM
I do not know about the internal structures of the Xilinx PLLs, but usually, PLLs running on higher freqs have a relatively shorter feedback loop, if you take the subsequent clock division into account.
