Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
0
Block ram inference with generate statement -> How to apply attributes?
[ Edited ]
Hello!
I'm manually trying to infer BRAM in a generate statement.
But if I do this:
gen_ramb16_s1_s36 : for i in 0 to 31 generate
attribute DATA_WIDTH_A : integer; --
      attribute DATA_WIDTH_A of gen_ramb16_s1_s36[i].RAMB16BWE_S36_inst : label is 9; -- Line 317
begin
RAMB16BWE_S36_inst : RAMB16BWE_S36
generic map (
          INITP_06 => X"0000000000000000000000000000000000000000000000000000000000000000",
          INITP_07 => X"0000000000000000000000000000000000000000000000000000000000000000")
port map (
DO => DO_RAM, -- 32-bit Data Output
DOP => open, -- 4-bit parity Output
ADDR => ADDR_RAM, -- 9-bit Address Input
          CLK  => tcm8230md_sys_clk,    -- 1-bit Clock
          DI   => DI_RAM,               -- 32-bit Data Input
          DIP  => (others => '0'),      -- 4-bit parity Input
          EN   => '1',                  -- 1-bit RAM Enable Input
          SSR  => '0',                  -- 1-bit Synchronous Set/Reset Input
          WE   => WE_RAM(i)             -- 4-bit Write Enable Input
end generate;
Doing so, ISE will still throw out the following error:
ERROR:HDLParsers:164 - "/home/DFK/FPGA_SVN/lib/CAM_TCM8230MD/trunk/tcm8230md_i2c_wrapper.vhd" Line 317. parse error, unexpected POINT, expecting COLON
what am I doing wrong????
Expert Contributor
0
Re: Block ram inference with generate statement -> How to apply attributes?
Line numbers are missing from source snippet ... which line is line 317?
- Bob Elkind
SIGNATURE:
Summary:
0
I added line number 317 as a comment now.
Expert Contributor
0
You're not inferring anything. You are instantiating. Please keep this straight, as it is not a trivial distinction.
Anyways, the real problem is that you should NOT use those attributes at all.
The generic map should have an entry called DATA_WIDTH_A which you should use instead of the attribute.
Yes, I do this for a living.
0
[ Edited ]
Hi and thank's for your reply.
It's true... it's not an attribute, it's generic...
This can easily be seen in the Libraries Guide .
Greetings,
     \h
Expert Contributor
0
diplomat wrote:
Hi and thank's (APOSTROPHE FAIL!)  for your reply.
You're confusing VHDL attributes with the "attribute" listed as something that can be controlled by modifying the generic through the generic map. Do not make this mistake.
Back in the Bad Old Days, the library primitives did not support the generic map construct for controlling how an instance of said primitive was built. At some point, the tools allowed generic maps, and for a while, generic maps and the VHDL attributes were both accepted (and in code that had both, the generic map had precedence).
VHDL attributes are now pretty much deprecated in favor of using generic maps. Delete the attributes, set the generic map correctly, and your design should go forward.
0
Hi bassman59,
that's true. I read *attribute* and without thinking further I thougt about classic vhdl attributes. :-/
