- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Re: How to declare two bit input in UCF of verilog
[ Edited ]- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
12-06-2010 09:21 AM - edited 12-06-2010 09:22 AM
You forgot the reg. This works for me. You will have to assign the one two three etc to the pin in the ucf.
module alu2bit(aluout,result,zero,one,two,three,four,five ,six,seven,eight,nine,a,b,select);
output [3:0] aluout,result; // the result
output reg zero;
output reg one;
output reg two;
output reg three;
output reg four;
output reg five;
output reg six;
output reg seven;
output reg eight;
output reg nine;
input [1:0] a,b; // input a and b
input [1:0] select;
reg [3:0] aluout,result;
always@(*)
begin
case (select)
2'b00:aluout=a+b; // For addition of two bits
2'b01:aluout=a-b; // For addition of two bits
2'b10:aluout=a*b; // For multiplication of two bits
endcase
zero <= (aluout==4'd0) ? 1'b1:1'b0;
one <= (aluout==4'd1) ? 1'b1:1'b0;
two <= (aluout==4'd2) ? 1'b1:1'b0;
three <= (aluout==4'd3) ? 1'b1:1'b0;
four <= (aluout==4'd4) ? 1'b1:1'b0;
five <= (aluout==4'd5) ? 1'b1:1'b0;
six <= (aluout==4'd6) ? 1'b1:1'b0;
seven <= (aluout==4'd7) ? 1'b1:1'b0;
eight <= (aluout==4'd8) ? 1'b1:1'b0;
end
endmodule
-R
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
12-06-2010 09:33 AM - edited 12-06-2010 09:34 AM
sir when i synthesize it i get the message
I have removed result as it is not used in code
after removing result i get this warning message
WARNING:Xst:737 - Found 4-bit latch for signal <$old_aluout_1>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems.
then when i tell it to generate bit file i get this message
pic attached
THIS is UCF
NET "a<0>" LOC = "L13" | IOSTANDARD = LVTTL | PULLUP ; //for a input
NET "a<1>" LOC = "L14" | IOSTANDARD = LVTTL | PULLUP ; //for a input
NET "b<0>" LOC = "K17" | IOSTANDARD = LVTTL | PULLDOWN ; // for b input
NET "b<1>" LOC = "D18" | IOSTANDARD = LVTTL | PULLDOWN ; // for b input
NET "select<0>" LOC = "H18" | IOSTANDARD = LVTTL | PULLUP ; //for select input
NET "select<1>" LOC = "N17" | IOSTANDARD = LVTTL | PULLUP ; //for select input
NET "one" LOC = "F12" | IOSTANDARD = LVTTL | SLEW = SLOW | DRIVE = 8 ;
NET "two" LOC = "E12" | IOSTANDARD = LVTTL | SLEW = SLOW | DRIVE = 8 ;
NET "three" LOC = "E11" | IOSTANDARD = LVTTL | SLEW = SLOW | DRIVE = 8 ;
NET "four" LOC = "F11" | IOSTANDARD = LVTTL | SLEW = SLOW | DRIVE = 8 ;
NET "five" LOC = "C11" | IOSTANDARD = LVTTL | SLEW = SLOW | DRIVE = 8 ;
NET "six" LOC = "D11" | IOSTANDARD = LVTTL | SLEW = SLOW | DRIVE = 8 ;
NET "seven" LOC = "E9" | IOSTANDARD = LVTTL | SLEW = SLOW | DRIVE = 8 ;
NET "eight" LOC = "F9" | IOSTANDARD = LVTTL | SLEW = SLOW | DRIVE = 8 ;
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
12-06-2010 09:38 AM
SIR bit file has been generated now
and let me check it
thanks sir for ur help
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
12-06-2010 09:39 AM
I tried to fix the code given and I think it will work as is. It would be more normal have a clock input and instead of
always @ (*);
use
always @(posedge clk);
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
12-06-2010 09:49 AM
Respected Sir,
Thanks my Kit is working now and my problem is solved.
I am highly thankful to all other people who helped me
I was very much tired.
My sincere apologies if i said something harsh.
It is b/c of u people that i using this FPGA kit
Take care
and thanks to Sir Roym Again
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
12-09-2010 09:18 AM
This warning is pretty crucial. If you look at this part of the code:
case (select)
endcase
"select" can have four values (2'b00, 2'b01, 2'b10 and 2'b11) and you've only told the system what to do for three of them. Basically, it doesn't know what to do to "aluout" when "select" is 2'b11, so strange things might start happening. I'd recommend fixing it.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
12-09-2010 09:28 AM
Good point, This was cleaned up in a later thread.
http://forums.xilinx.com/t5/Spartan-Family-FPGAs/H
-R
