- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
MIG ploblems in spartan6 sp601
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-21-2012 07:16 PM
hello everybody....
I am attempting to use the SP601 MIG reference design (RDF0005) by following the directions in XTP039,, but i have a problem:
ERROR:NgdBuild:604 - logical block 'gen_dbg_enable.my_ila_c3' with type 'ila'
could not be resolved. A pin name misspelling can cause this, a missing edif
or ngc file, case mismatch between the block name and the edif or ngc file
name, or the misspelling of a type name. Symbol 'ila' is not supported in
target 'spartan6'.
ERROR:NgdBuild:604 - logical block 'gen_dbg_enable.my_icon_c3' with type 'icon'
name, or the misspelling of a type name. Symbol 'icon' is not supported in
target 'spartan6'.
ERROR:NgdBuild:604 - logical block 'gen_dbg_enable.my_vio_c3' with type 'vio'
name, or the misspelling of a type name. Symbol 'vio' is not supported in
target 'spartan6'.
so what can i doing??
thanks in advance
Solved! Go to Solution.
Re: MIG ploblems in spartan6 sp601
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-22-2012 06:20 AM
The items that are causing the error are ChipScope cores. If you don't have a license
for ChipScope you should turn off the generation of these connections. The name
of the components implies that they were generated based on a debugging enable
generic (or parameter). You can probably find this in the top level instantiation of
the core.
-- Gabor
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-22-2012 03:51 PM
I relly thank you for reply...
I removed now all Chipscope components(icon, ila and vio) , the synthesize is done but I fall in another problem :
ERROR:Pack:2309 - Too many bonded comps of type "IOB" found to fit this device.
ERROR:Map:237 - The design is too large to fit the device. Please check the Design Summary section to see which resource requirement for your design exceeds the resources available in the device. Note that the number of slices reported may not be reflected accurately as their packing might not have been completed.
although that I applied all the steps exactly as shown in the directions in XTP039...
so, what can i doing now??
did you have any MIG reference design except (RDF0005) To learn from it ...
thanks in advance
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-23-2012 02:48 AM
You are going to need a bigger FPGA.
Or else drive the MIG-generated controllers 'ap' interface from logic inside the FPGA.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-23-2012 05:15 AM
This error can happen if you try to build the MIG core as the top level. In that case all of the user
interface side signals (app_*) get mapped to I/O pins, and there aren't enough pins for that.
If you want to build a test project, you need to use the one provided as an example, or at least
build the MIG with the integrated synthesizable testbench.
- Gabor
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-25-2012 11:34 PM
sorry , how can i cancel this solution option, i fall in many errors after the selection , and i need to Keep the door open for discussions..
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-26-2012 03:06 PM
Maybe a moderator can remove the solution from this thread, but it's probably
best to just start a new thread to ask any further questions. If necessary you
can add a link to this thread by just copying and pasting the URL.
-- Gabor
