Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
Regular Contributor
neam
0
Accepted Solution
MIG ploblems in spartan6 sp601
ERROR:NgdBuild:604 - logical block 'gen_dbg_enable.my_ila_c3' with type 'ila'
   could not be resolved. A pin name misspelling can cause this, a missing edif
   or ngc file, case mismatch between the block name and the edif or ngc file
   name, or the misspelling of a type name. Symbol 'ila' is not supported in
   target 'spartan6'.
ERROR:NgdBuild:604 - logical block 'gen_dbg_enable.my_icon_c3' with type 'icon'
   name, or the misspelling of a type name. Symbol 'icon' is not supported in
   target 'spartan6'.
ERROR:NgdBuild:604 - logical block 'gen_dbg_enable.my_vio_c3' with type 'vio'
   name, or the misspelling of a type name. Symbol 'vio' is not supported in
   target 'spartan6'.
Expert Contributor
gszakacs
0
Re: MIG ploblems in spartan6 sp601
The items that are causing the error are ChipScope cores.  If you don't have a license
for ChipScope you should turn off the generation of these connections.  The name
of the components implies that they were generated based on a debugging enable
generic (or parameter).  You can probably find this in the top level instantiation of
the core.
-- Gabor
-- Gabor
Regular Contributor
neam
0
I relly thank you for reply...
I removed now all Chipscope components(icon, ila and vio) , the synthesize is done but I fall in another problem :
ERROR:Pack:2309 - Too many bonded comps of type "IOB" found to fit this device.
ERROR:Map:237 - The design is too large to fit the device.  Please check the Design Summary section to see which resource requirement for your design exceeds the resources available in the device. Note that the number of slices reported may not be reflected accurately as their packing might not have been completed.
although that I applied all the steps exactly as shown in the directions in XTP039...
so, what can i doing now??
did you have any MIG reference design except (RDF0005) To learn from it ...
 thanks in advance
Expert Contributor
rcingham
0
"The design is too large to fit the device."
You are going to need a bigger FPGA.
Or else drive the MIG-generated controllers 'ap' interface from logic inside the FPGA.
"If it don't work in simulation, it won't work on the board."
Expert Contributor
gszakacs
0
This error can happen if you try to build the MIG core as the top level.  In that case all of the user
interface side signals (app_*) get mapped to I/O pins, and there aren't enough pins for that.
If you want to build a test project, you need to use the one provided as an example, or at least
build the MIG with the integrated synthesizable testbench.
- Gabor
-- Gabor
Regular Contributor
neam
0
sorry , how can i cancel this solution option, i fall in many errors after the selection , and i need to Keep the door open for discussions..
Expert Contributor
gszakacs
0
Maybe a moderator can remove the solution from this thread, but it's probably
best to just start a new thread to ask any further questions.  If necessary you
can add a link to this thread by just copying and pasting the URL.
-- Gabor
-- Gabor
