Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
0
Accepted Solution
Pack:2531 - The dual data rate register "clock_clk_5p3M" failed to join
I am trying to direct a generated clock with pll towards an out pin, using ODDR2 and  OBUF, however i got this error
"Pack:2531 - The dual data rate register "clock_clk_5p3M" failed to join    the "OLOGIC2" component as required"
Would you please help? see below the code.
ODDR2 #(
      .DDR_ALIGNMENT("NONE"), // Sets output alignment to "NONE", "C0" or "C1"
      .INIT(1'b0),    // Sets initial state of the Q output to 1'b0 or 1'b1
      .SRTYPE("SYNC") // Specifies "SYNC" or "ASYNC" set/reset
   ) clock_clk_5p3M (
      .Q(v_CIS_test_clk),     // 1-bit DDR output data
      .C0(s_CIS_test_clk),  // 1-bit clock input
      .C1(~s_CIS_test_clk), // 1-bit clock input
      .CE(1'b1),      // 1-bit clock enable input
      .D0(1'b1), // 1-bit data input (associated with C0)
      .D1(1'b0), // 1-bit data input (associated with C1)
      .R(reset),   // 1-bit reset input
      .S(1'b0)   // 1-bit set input
  OBUF #(
      .DRIVE(12),   // Specify the output drive strength
      .IOSTANDARD("DEFAULT"), // Specify the output I/O standard
      .SLEW("SLOW") // Specify the output slew rate
   ) OBUF_CIS_test_clk (
      .O(CIS_test_clk),     // Buffer output (connect directly to top-level port)
      .I(v_CIS_test_clk)      // Buffer input
0
Re: Pack:2531 - The dual data rate register "clock_clk_5p3M" failed to join
The outputs of ODDR2 should go to the output PAD's through the OBUF, and the outputs of ODDR2 cannot be looped back into the FPGA's internal logic. This is shown below.
Please check in case if you are looping back from ODDR2 ouputs which is causing the problem. Also post the complete error message.
Deepika.
Google your question before posting.
If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left)
0
Hi Deepika,
Thanks a lot, problem solved, the output of my ODDR2 was looped back into the FPGA's internal logic.
Kuti
0
Hi Kuti,
Good to learn that it works.
Please mark the thread as solved by accepting the post as solution.
Deepika.
0
Marked as an answer for future references.
