- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Re: Spartan-3E , DDR, MIG
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-19-2009 03:40 AM
Hi Sanjaac,
thanks for your reply...with attribute "soft" now the design compile!!!!
I test the first task "the ddr initialization" and everything goes well.
Now I would write some data, but I do't understand well the timing diagram on UG086 page 254 figure 7-9 (see the attach)
my first question : what is D0,D1, Dx..? is D0 a word of 4 byte?So every burst I'll write 32 bytes of data?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-20-2009 12:33 AM
Hello Alex.
Since it is a dual data rate memory, 16 bits wide, each tick of clk90 (which is the same as clk0, and in my case is a 100 MHz clock) writes 2x 16 bit words. This diagram is for a burst length of 4, which is also what I use in my design. So, each of those bursts writes actually 8x 16bit words. In my case I go a bit further, in the sense that I execute the burst_done cycle only when a full row is written, thus boosting the access time.
The generation and control of those signals is what goes inside the huge State Machine, which as I said, also generates the Dx data and Rows where to write to / read from. Soon I will post a cleaner code, which isolates this and can be used more effectively.
Regards.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-20-2009 12:52 AM
Correction:
"[...] clk90 (which is the same as clk0, [...]" clk90 has the same rate as clk0, but is phase shifted 90 degrees.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-20-2009 03:24 AM
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
03-08-2013 09:36 PM
Hi Jaac
can you please share what code did you use to implement the memory(ddr). You have written that you implemented TestMemory App..so can you please share its source code as I am unable to open your project in Xisilinx ISE 12.3..It says that the older format project has some files missing. So just share the TestMemory app code and rest I will implement on my own.
Thankx in advance
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
03-10-2013 04:46 AM
It was a customer project, I can not share the sources more than what I already did on the forum.
Good luck,
JaaC
