Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
kanwal_
0
how to instantiate ODDR block?
hi
please tell me how to instantiate ODDR block to remov DCM clocking error 1203 in spartan 6......plz urgently give me the ans?
Super Contributor
wuher
Re: how to instantiate ODDR block?
Expert Contributor
eteam00
0
Using ODDR for Clock forwarding
[ Edited ]
If you reference a specific error message code, you should include the text of the error message in your post.  I am not familiar with "DCM clocking error 1203".
If the question is:
How do I forward an internal global clock to an output pin?
the answer is an approach which is
  • well documented
  • applies (generally) to all FPGA families
  • called 'clock forwarding'
Specifically, try the following:
  • Open ISE
  • Click on the 'light bulb' icon to bring up the Language Templates window
  • Follow Verilog (or VHDL)>Synthesis Constructs>Coding Examples>Misc>Output Clock Forwarding Using DDR
  • Read the Info section, as well as the family-specific sections
For Verilog and Spartan-6, you will find the following example:
   // Clock forwarding circuit using the double data-rate register
   //        Spartan-3E/3A/6
   // Xilinx HDL Language Template, version 13.4
   ODDR2 #(
      .DDR_ALIGNMENT("NONE"), // Sets output alignment to "NONE", "C0" or "C1"
      .INIT(1'b0),    // Sets initial state of the Q output to 1'b0 or 1'b1
      .SRTYPE("SYNC") // Specifies "SYNC" or "ASYNC" set/reset
   ) clock_forward_inst (
      .Q(<output_clock>),     // 1-bit DDR output data
      .C0(<internal_clock>),  // 1-bit clock input
      .C1(~<internal_clock>), // 1-bit clock input
      .CE(<stop_clock>),      // 1-bit clock enable input
      .D0(1'b0), // 1-bit data input (associated with C0)
      .D1(1'b1), // 1-bit data input (associated with C1)
      .R(<hold_clock_low>),   // 1-bit reset input
      .S(<hold_clock_high>)   // 1-bit set input
   // End of clock_forward_inst instantiation
The following example showing clock forwarding to an output pin is edited from UG382, Figure 3-13:
-- Bob Elkind
SIGNATURE:
Summary:
kanwal_
0
Re: Using ODDR for Clock forwarding
hi, thanks for your quick response ...,,,
//actually i made a following verilog program
module (clk_in,clk_out1,clk_out2)
input clk_in; output clk_out1,clk_out2;
// instantiate dcm
mydcm 1 (
  .CLK_IN1(clk_in1),
  .CLK_OUT1(clk_out1), // same as input clk
  .CLK_OUT2(clk_out2)  // clk2x
endmodule
during mapping i get following error :
"ERROR:Place:1136 - This design contains a global buffer instance,
   <uut/clkout1_buf>, driving the net, <CLK_OUT1_OBUF>, that is driving the
   following (first 30) non-clock source pins.
   < PIN: CLK_OUT1.O; >"
to solve this problem i add oddr2 in my prog but still get the same error please help me to solve this problem
i shall be very thankful to you.
aliaarshad
0
"clock_forward_inst" failed to join the "OLOGIC2" component as required.
hi,
i tried to instantiate oddr2 in my verilog program bt during mapping it gives the following error
Pack:2531 - The dual data rate register "clock_forward_inst" failed to
join the "OLOGIC2" component as required. The output signal for register
symbol clock_forward_inst requires general routing to fabric, but the
register can only be routed to ILOGIC, IODELAY, and IOB.
ERROR:Pack:2531 - The dual data rate register "clock_forward_inst" failed to
join the "OLOGIC2" component.
how to overcome this problem?
i will be very thankful for your response.
thanks
aliya
Expert Contributor
eteam00
0
please start a new thread
[ Edited ]
Aliya, please start a new thread to discuss your separate problem.  This thread is for discussing kanwal's design.
-- Bob Elkind
SIGNATURE:
Summary:
Expert Contributor
eteam00
0
[ Edited ]
Kanwal,
You have signals connected improperly, including a clock signal driving non-clock pins.  If you cannot fix this on your own, then please post your source code which includes all clock signal connections and references.
A BUFG output cannot drive an OBUF input directly.
-- Bob Elkind
SIGNATURE:
Summary:
bwade
0
Re: "clock_forward_inst" failed to join the "OLOGIC2" component as required.
The ODDR in the OLOGIC component has very limited connectivity. Usually it should be driving a single output buffer. The error message indicates your ODDR is driving fabric logic which cannot be supported.
