Sign In
Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
zohair01
0
Accepted Solution
Any way to initialize on board BRAM?
I have BRAMs in my design. During simulation I used coe files to generate mif files to act as initialization for the RAMs. But is this possible during synthesis? Am I able to transmit memory information along with the bit file?
Expert Contributor
rcingham
0
Re: Any way to initialize on board BRAM?
Which FPGA?
What version of tools?
Are you inferring the BRAM, or did you use the 'Block Memory Generator'?
"If it don't work in simulation, it won't work on the board."
Expert Contributor
eilert
0
basically yes.
Even after Place & Route you can change the BRAM initial values in the bitfile with the data2mem tool without needing to rerun the whole implementation.
Read the data2mem documentation for details.
Have a nice synthesis
   Eilert
Super Contributor
barryabrown
0
You initialize the block ram in coregen with your coe file - the resulting ngc includes the initial values.  Since you have created a coe and generated a mif, you have probably done this already.
Barry
zohair01
0
I see. I was under the impression that since the mif file was generated, that it is only for simulation. OK. That makes sense. Thanks.
