- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Array of vectors into task/funct ion
[ Edited ]
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
04-01-2011 02:29 AM - edited 04-01-2011 02:30 AM
Is there a way to pass a variable length signal to a task or function in verilog?
I have a small generate loop that flattens a signal (to pass an array of vectors into a module), but I have to flatten several signals. Is there a way to avoid all that code repetition? Especially because the module is heavily parametrized and I'll have to flatten "n" signals. So a function or task would be ideal.
Re: Array of vectors into task/funct ion
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
04-01-2011 04:29 PM
You need Systemverilog. Which ISE doesn't support. :(
Array of vectors etc are quite powerful tools - you just can't really use them effectively
with ISE as your finding out.
We've learned to just flatten EVERYTHING, and just become efficient at indexing
into to flattened vector appropriately.
I.e. Lots of code like
parameter N = 10;
wire [ N * 32 - 1 : 0 ] foo_vector;
// wire[ N - 1: 0 ] [ 31 : 0 ] foo_array = foo_vector; // Systemverilog packed array - what we really want;
genvar i;
inst bar ( .a( foo_vector[ i * 32 +: 32 ] ), ... );
Array's of instances are handy too - if you're calling "N" identical submodules - just
want inputs/outputs vectored off of the flattened arrays:
inst bar[ N - 1 :0 ] ( .a( foo_vector ), .b( baz ) );
Parameterized function/tasks just aren't available - even in Systemverilog.
The SystemVerilog working group even weasled out on adding it to the next version of
SystemVerilog by noting that you can work around it by sticking the functions
down as methods inside classes (which can be parameterized). That
doesn't help for synthesizable code however. Sigh.
--Mark
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
04-02-2011 01:22 PM
Hey mark, thanks for replying
Yeah I've noticed that ISE is quite picky syntax wise, sadly. Also while I was working I came across the notions of packed and unpacked arrays and etc. But I couldn't find a decent explanation of how they are indexed.
What's the difference between these;
reg [31:0] somesignal [5:0]
reg [31:0][5:0] somesignal
reg [31:0][5:0] somesignal [5:0]
and how can I index each group of bits as "rows"?
Also another thing, I have a nested generate (taken from ISE's code templates):
genvar i, j;
generate
for (i=0; i < NUM_OUTPUTS; i=i+1) begin: case_for //outter case loop
for (j=0; j < NUM_INPUTS; j=j+1) begin : case_statements //case statements
if(reg_select[NUM_SEL_BITS + (NUM_SEL_BITS * i) : (NUM_SEL_BITS * i)] == j)
begin
assign `CHUNK(i,output_registers) = `CHUNK(j,input_registers);
//output_registers[i] <= input_registers[j];
end
end //end case_statements for
end//end case_for loop
endgenerate
Why does ISE complain about reg_select not being constant?? Before it also said "j" was a non reg so the assignment j=j+1 was invalid...
bandit
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
04-04-2011 05:14 PM
A brief intro to SystemVerilog arrays can be found here:
http://www.doulos.com/knowhow/sysverilog/tutorial/
All very good to know - however you can't use this with Xilinx :(
/////////////// genvar i, j;
generate
begin
end
endgenerate//////////////////////////////////////////////////
The array index you've got:
Is NOT valid. Yes, both you and I know that no matter what 'i' is the final selected range
of reg_select is always going to be NUM_SEL_BITS. However it's a little
harder for the verilog compiler/synthesizer to know this. So from early on verilog, this
type of indexing has been illegal. In Verilog 2k, they added some new operators:
'+:' and '-:'
This allows you to do what you want. Recode the above to:
reg_select[ (i*NUM_SEL_BITS) +: NUM_SEL_BITS ]
The key to making this work is the left side of the index can be variable.
The right side of the '+:' must be a constant (or parameter). This way
the compiler/synthesizer always knows the result will have a constant
width, and is happy.
--Mark
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
04-21-2013 03:16 PM
Minor point: the # of bits in:
is of course, NUM_SEL_BITS+1
